Armourdillo
- Sep 28, 2015
considering 750ti/950/960
my monitor now only supports 1680x1050 and i can only foresee myself going to 1080p if i were to upgrade in the near future, not 1440p so maybe a 970 would be overkill.
main uses really just dota2 best settings maybe some other newer games but im perfectly fine with playing them on like medium/low settings.
other specs
ASRock H81M-HDS /i5-4460
8gb ram
SF Leadex 90+ 550w Silver
CM N200
For reference the prices im looking at from Lazada
Palit Geforce GTX750 Ti StormX Dual 2GB GDDR5- $157.25
ZOTAC Geforce GTX 750 Ti 2GB GDDR5- $170.05
Palit GeForce GTX 950 StormX Dual 2GB GDDR5 - $232.75
Palit GeForce GTX 960 JetStream 2GB DDR5 PCI-E Graphics Card - $279.30
ZOTAC GeForce GTX 960 Twin Fan 2GB GDDR5 OC- $284.05
Some questions I have:
1)
First timer qn: if i build the whole pc and a part spoils (say gfx), how do i go about requesting for repair/exchange. Do i have to remove the specific part from my pc? or can i just bring down my whole pc? (both if i were to purchase parts from PCThemes or Lazada)
2)
3 Years Local Manufacturer Warranty vs 5 Years Local Supplier Warranty (Palit vs Zotac)
Palit 3 years means full 3 years by convergent locally, while zotac is 2+3 means 2 years tech dynamic locally and the next 3 years i have to send to zotac directly overseas? (or will tech dynamic still handle my card if i registered)
3)
Are all the cards compatible with the intended system? (Mobo and casing)
4)
Which will be the one that bottlenecks my system apart from my monitor. My CPU i5 4460 or a 950/960
5)
In the case of microsoft software swap, do I save a recovery copy of W7 (which I'm purchasing) or W10 (which I'm immediately upgrading to)
other specs
8gb ram
CM N200
1)
2)
3)
4)
5)
