Not blu ray quality? Thats weird. I watched all the ep in blu ray online alr anyways, big screen and surroud sound shld be more epic![]()
nwas there just now and i tink its still sold out for mg sinaju titanium version. and i thought its a 1 day offer only?
rg clear rx 78 n strike rouge sold out as well.
n
when there just now, they told me i can try hga at sunshine plaza or other departmental stores(which IMO its difficult to find the model)... its only for that day, if u go late means u have to try other shops. i might be going to hga to see if they got stock on that model or not, damn chio lo when i saw it... each day they got different models for sale, sold out means sold out... these are the few of the popular n chio models...
Hi,
I would like to know if tools like plastic nipper, Gundam Markers etc are available at the Gundam Expo at Nex?![]()
the only brand of nippers you should buy is GOD-HAND![]()
Hi,
Hi,
But the price????
Yes. I bought some gundam markers there. The nipper are quite expensive though... $26 a pair. Though, you might not think it is...
Thanks! Will head down and have a lookBut the nipper is it worth it?
I m using a $48 nipper.. Not saying I pro or wat.. But to give advice now.. U pay for wat u get.. The cut is very clean n good..
I agree.. I'm using Tamiya sharp pointed side cutter ($48), and it's very sharp... I think it's a good investment, since it can last more than 10 boxes of MG kits... mine lasts 1 RG, 5 MG, 1 PG, still counting. but try not to buy the lower end products of tamiya, like the basic tool set (nipper + cutter + screwdrivers + files), since they're basically cheap stuffs that are labeled tamiya. I don't think they're worth the price. better get the $48 cutter instead.
oh and when I went to Japan, I bought another side cutter, it was around JPY 1600, which is much cheaper than $48 retail price in Sg.![]()
I want to upgrade to a proper side cutter, $48 is way too steep. Any alternatives? Looking for files too.
Thanks for the heads up! What is difference between the 2 models?Hi Guys! Since you all are mentioning about plastic nippers here, I will like to recommend below 2 models which I have been using since I started my modeling hobby. I bought both for around $20+ each last time which I think it's really very reasonable price compared with those $40+ cutters u guys discuss here.
They are 100% made in Japan by a company called 3.PEAKS. They are very famous cutters & pliers manufacturing company in Japan because of their workmanship and quality. Personally after using them for so long, the blades are still very sharp and leaves very clean cut. Blades have not rust yet cos its stainless steel material which is a plus point too.
I did some research and found out there's a local distributor for this brand in Singapore call Ekon Hardware. You guys can give them a call for more information.
3.PEAKS SP-23 Plastic Nipper
3.PEAKS SP-33 Plastic Nipper
