gentoro
jus competed a rg zeta. wanting to do water decal, any 3rd party water decal available for this kit?
simwb90
i know this is a Gunpla thread but not knowing where to start, i decided to ask here...hope you guys can help me out...
anyone here familiar with where i can grab Zoid kits in SG? the ones im looking for in particular are Lightning Saix, Blade Liger AB and Berserk Fuhrer...all from Kotobukiya HMM series
thanks >.<
k3nzor
thanks >.<
M Workshop. Saw a few boxes of Zoid kits there few days ago.
ultimatron
thanks >.<
u can try TFH
The Falcon's Hangar
freshmeat81
I just found There's a shop in china square central 2nd floor 2nd or 3rd shop on the right side of the escalator that sells most of the kits u listed. Not sure if cheap but their transformers stuff are pretty reasonable.
thanks >.<
simwb90
hmmms that's a new place that i didn't know of...will need abit more details if possible...considering i've never been there >.>
gentoro
Go there on sunday only. Jus been there today. Nothing much. Oh dear, jus got the samuel decal for rg zeta. So freaking tiny! Any issue of hobby jap got eg. Where to paste the decal? Only manage to used 10% of it, will continue nxt weekend.
guiltysky
Any bro here can provide some advice for me?
I am having problem with the gold color while spraying on white part with gold spray cans. The gold color looks rusted after i applied the gold spray on it, really a undesirable effect>_<.... all the part are fully sanded , prime b4 painting. Any bro down here who encounter the same problem as me b4? And also does this problem occur only when applying gold on white parts or is there any special method that must be applied when painting gold , i have no problem when spraying with sliver though...
GamesCreditAsia
spray a layer of gloss black first............
guiltysky
hmm , i do not have a gloss black spray cans at the moment , but i do have a black color spray cans(matt black) , does spraying the matt black help to solve the problem instead of having to use gloss back? lol..sorry i very noob at gunpla...
Cleaver
Hi, may i know did you shake the can thoroughly before spraying?
Isit from Tamiya or some other brand of spraycan?
Maybe can attach a pic, it'll help a lot.
Applying gloss black before gold will make the gold color more bling, thus matt is not recommended.
jino06
Can anyone point me to where I can still buy the Metal Build Freedom Gundam? I know its a bit of a stretch since it was released last year. But maybe some shop still has one :) Second hand would be an option as well. Thanks.
ongkh2000
visit china square central on sundays, they have a flea market there. or second option is to post a want to buy thread in the hobbyist bazaar.
HeeroYuy
To spray bling or shiny metallics,a glossed base is adviced. If want a rough texture then you use a matt base.
Knightrider3K
bundle set?...
guiltysky
hey bro , thx for the reply man , hmm yea it a tamiya spray cans , think will switch to other color instead of using gold(cause after building some of the parts , i tried to assemble it and see how it look like and found out that gold doesn't look actually good with it) , i do have another question though , how to fix the bubbles that pop up after spraying>_<?
sand it first than prime again or
prime it first , sand , prime again?
pai seh i really dam noob at gunpla>_<
ongkh2000
if got bubbles.. most prob is because u spray too close n too thick.. spray from a slightly further distance and do fast mist coats, that will help to lessen the chances of bubbles.
u should sand smooth, prime then paint. or if u lazy, just skip the priming and go straight to paint
