Noctilucence
- Dec 5, 2007
Wah gg la. I use mcspicy oil, my cutter rust immediately. And i always thought mcdonalds more healthy than kfc.
Apart from this bull****, i usually use a exacto knife to remove the nubs and sometimes i cut really badly. Apart from sanding, is it possible to just cut and trim nicely most of the time using just a cutter?
actually cutter + exacto knife is sufficient:
Nub Removal |
problem is your knife needs to be sharp.. "dip-into-flowing-stream-and-will-cut-any-leaf-floating-pass" kind of sharp.
