000kai000
very long never touch gunpla already...
but saw MG SAZABI ver KA... cannot resist! went down to HAG to preoreder today! :s12::s12::s12:
deathgazer
anyone saw this gundam before? any idea what grade is this? i saw one zeta also at tokyo before n its grade is even bigger den PG n mega size gundam
Blusttoy
If I am not wrong, that is a 1/35 G-System Resin kit for the MSA-0O11 [Ext] Ex-S Gundam.
Please look here for more pictures: G-System-Shop
Priced at USD 2,517 :s13:
osirisx
i will try to ask HAG. Hopefully they can help
also lost a small part last time
hag last time I asked before, they dun have it
if u live in japan or have frens there u can get a free one-time replacement
u can also order overseas iirc was a US website (gginfinite) but very ex, I got a quote from them (coz u need to get the entire tray for that piece)
hence I diy a remold, not the prettiest, but works to keep it in place
then sometime later I found the missing part and fixed it back
bootleg means the "ahem" brands
dragod
Sad liao......So how much you pay for the whole tray?
How to recast??
Ahh... no wonder I went to KL and saw this shop selling their Gundam kit so cheap, so those are Bootleg......
Blusttoy
Any online sites that sell cheap SD gundam models?Wanted to put some on display lols
For online, I go to the major website at: Hobby Search or Hobby Link Japan.
Given the shipping, if you're not planning to buy a lot, I think SD kits are better purchased at local hobby shops. Metro has tonnes but of course it's quite expensive for SD kits. There's also those Hobby Art, Hobby Point etc for cheaper and larger selection range.
Are you looking for those Dynasty types or the normal looking ones?
Alternatively, you may want to look at Gundam Converge, a completed Gundam figure line that have chibi proportions.
Personally, I think you get 1 Destiny Metal Build, is a magnificent display already.
And Deathgazer, if it's official Bandai product, I think biggest is 1/12 Display unit:
But some people will smartass say biggest Gundam kit is 1/1:
The most realistic buyable option is of course the 1/48 scale Gundam/Zaku.
And dragod, ya, bootleg is the most feasible option you have as it's troublesome to order the tray. I tried checking price to get the trays for HGUC EX-S Beam Smart Rifle and got quoted a price higher than the kit itself.
But bootleg isn't all fun in a cheap price. If you always use Bandai product, once you try the fitting and the plastic material, sure vomit blood. My MC Model kits still in boxes cause I wanna cry remembering the Nu's fin funnels poor fit.
deathgazer
thanks Blusttoy. haha that RX 78-2 1/12 looks good, but doubt it will be selling also. the 1/35 G system resin kit is already very huge imo. I already got gundam age 1 mega size so was wondering n looking for something bigger then that
osirisx
How to recast??
didn't buy the tray as it was very ex
recast forgot how I did it (too long ago), using putty and powder to "clone" the missing part u need a matching piece for that
just google it
JulyStork
What do you do when the nib of your gundam marker slips out of the groove & makes smudges? Tissue paper & erasers just spreads the smudge even more. I read somewhere Q-tips with zippo fluid helps, that true?
micheloving
Do most SD models require painting or look like the ones shown on the boxes?
Any glue needed?
aucheukyan
Any glue needed?
if you snapfit, it will look the same, except of some colours and details are not present despite having stickers to stick on. There will be seamlines too between parts. It is better to use glue and some kind of putty to fill the seams.
If you are fine with the seams or is new to plastic models, then just snapfitting will be fine
