anhyeuem
Can somebody kindly tell me where to buy all the equipment to build an air brush box? (Included the box, the pipe, the fans...)
I ask some shop and they quote me S$ 300 ++ for a box :s22::s22::s22:
Visit the website 2013 plamo, Google it. Search the thread spray booth. Sorry on mobile now maybe u drop me a pm if u still cannot find. All in should be less than $100. I did post mine in this thread search it.
RedEyesFan
bought this at Taka today.
zzzzzzzzzzzzzzzzzzzzzz:(:(:(:(
Reborns
guys
quick question
anybody seen Copic Modeller 0.02mm panel line markers around?
where to buy and how much
Shadow X
Anyone can give me some advice?
Recently just started to do lining to my HG Sinanju and also, I did a top coating for it. The lining wasn't perfect since I did it at night (I think I will start to do lining only during daytime for the actual sunlight to reflect the plastic better).
I used a semi-gloss top coating for my Sinanju. I did about three 360 degree spray, having a 15 minutes "drying" up process for each 360 degree spray job. The question now is, I don't know whether my Sinanju is properly coated. If I use the semi-gloss, it is suppose to have some reflective and abit of rough surface right? When I touched some of the outside parts, it is rough while some are abit still smooth.
Note: First time doing lining and coating. I top coat directly from the factory build so no painting or whatsoever. Top coating was done after assembly so I sprayed the whole mobile suit.
Thanks!
thegamer1907
Thanks!
i think for the rough parts u sprayed abit too far from the kit which causes the topcoat to dry slightly before hitting the surface hence giving a rough surface.
xfiles_wolvie
FINALLY, finishing all my SDs. Last 3 kits.
looks fierce overall. liked the backpack. little gold leafing to add to the bling.
another wings kit. hw can not like the fiery wings? also like the weapons system.
xfiles_wolvie
and there is my last one.
after some success of the flat gold leafing, itchy backside try on curved again...sigh. turned out slightly better than guntank but still sucks.
wilfredgod
bearguysan
hello I have been into gunpla for close to 2yrs liao, this is my bearguysan, jus feel that I shld share# so damm cute.. painted different yellow and glossy! :p
11393147865
11393146525
AikiBoy
OMG I drop my beargguy twice. grap its head, the body drop off and fall shoulder height, panic bring up and slip off again drop and slide quite a distance...:s13: not break.. nothing... tough kit.:eek:
cannot imagine if i drop my rg kits... sure cui...
11393147865
11393146525
cannot see pic... :o
alfseeto
Currently in Sapporo. Bought this yesterday at Bic Camera with tax rebate came up to 6251 yen. So many gunpla to buy, not enough luggage space.
