kenneth0601
Hyaku Shiki MG ver2.0
valentinotan
taobao seller does not ship direct to SG. You need to use parcel forwarder. check out this link http://sea.taobao.com/market/act/parcelforwarding.php .
I've been using 4PX ..so far no issue. the biggest item i've bought was MG Rx-93 Nu Gundam Ver.Ka and was charge 1.7kg
or u can use 65diagou to shop for you. http://www.65daigou.com/WhyChooseUs . They charge by volumetric weight (kg) = length x height x width (cm)/ 6,000
recently i tried daigou for MG STRIKE FREEDOM Full Burst mode and was charge S$22.10 for 5.76kg by sea (Actual weight 2kg).
Item not here yet so don;t know why the box is so huge that i was charged for 5.76kg
based on 1999.co
RX-93 Nu Gundam Ver.Ka (MG) http://www.1999.co.jp/eng/10197156
Item Size/Weight : 39.2 x 31.3 x 11 cm / 1163g
ZGMF-X20A Strike Freedom Gundam Full Burst Mode (MG) http://www.1999.co.jp/eng/10051948
Item Size/Weight : 59.2 x 32.3 x 9.4 cm / 1254g
Thanks bro. Really appreciate it.
Sent from the future using GAGT
tissuepaper
if want to start using pla-plates, what depth will be good to use ? there's a few. 1.5mm , 0.5mm , 0.2mm
and anyone using rotary tool for sanding ?
anhyeuem
Thx for all the suggestions. I would be buying nu ver Ka, mg sinanju, hg kshatriya, hg psycho and a few Rg kits. I'm afraid my luggage isn't big enough to fit all these :(
Sent from the deep that Adele is rolling in using GAGT
if u past by Ueno station, there is a luggage shop just below the bridge at the big crossing. Sells a cloth bag that is huge at abt 900~1000 yen. It could fit like 2 MG and couple of small kits. Then check in as fragile.
Also storage lockers at the station itself. Coin operated.
osirisx
Possible to bring back 3 PG from jpn ?
e.g unicorn, 00 & sf
With their add-ons included?
Errz
http://gundamguy.blogspot.sg/2015/06/gundam-docks-at-hong-kong-ii-time.html
Gundam Docks at Hong Kong II Exclusive Gunplas:
- MG 1/00 Unicorn Gundam “Ver. Ka" [CODE_852]
- RG 1/144 WING GUNDAM ZERO EW Ver. GUNDAM docks at Hong Kong II
- HGUC 1/144 RX-0 UNICORN GUDAM [DESTROY MODE] Ver. GUNDAM docks at Hong Kong II
- HGBF 1/144 BEARGGUY III [SAN] Ver.囍
- HGBF 1/144 TRY BURNING GUNDAM FULL COLOR COATING Ver.
babymonster
Just to share some info. I bought PG Strike Rouge from TaoBao.
Package weigh 3.5KG
Using 4PX to ship to SG and delivery to home. SGD$25($115rmb)
