evilerniex
Guys, any idea where in Tokyo to buy cheap and rare Gundam? Also for SRW Kotobukiya?
Prefer in 1 location for shopping...
just go akihabara.
go yodobashi camera dept store for cheap kits.
for rare ones, u will have to hunt for them in smaller shops in akihabara
if u are looking for Gundam Tokyo Front (GTF) editions, go to the GTF store in Divercity in Odaiba
there is a Kotobukiya shop in akihabara. but I am not into koto, so didn't compare the price.
haremdevil
yodobashi camera
just go akihabara.
Thanks..
Relatives going Tokyo...asking them to hoot some kits for me...:D
haremdevil
what kind of kits you looking for ?
usually spend above 10 000yen can get tax rebate for bic camera/ yodobashi
Very hard to find in SG..even internet as well....
haremdevil
the musha gundam tokugawa is p-Bandai or limited edition if I am not wrong.
yodobashi or bic camera will not have it. have to hunt for them in smaller shops
It's limited edition...
Yup..I know will be hard to find in those standard malls....:(
But have to try la....For those smaller shop that you mention...is it around yodobashi area?
But I more concern on Alteisen and Cybaster....
Altesien is the 1/100 scale...its being discontinue for a long time....
That Cybaster is the premium edition...not sure if got in their shop anot...
evilerniex
smaller shops in akihabara.
yodobashi is a dept store... there is one in akihabara, and also in ueno and Shinjuku
not familiar with koto. but for normal range, even if it is old ones, yodobashi may still have
Xahnus
Good day everyone.
Can anyone recommend what I should do to remove nub marks from my clear parts?
I've read about sanding, is that the only way? How much sandpaper is considered enough to target the nub mark?
Thank you in advance!:)
evilerniex
Good day everyone.
For clear parts u shldnt be sanding it. Sanding will dull the surface no matter how fine ur sandpaper.
U can only try to cut as close as possible and use knife to slice watever is left
Sent from nowhere without using GAGT
Bryson
choonfatt
Hi like to seek advice on how to achieve metallic white like white cars. Sand to smoothness, paint and gloss coat?
Can painted surface be sanded?
tissuepaper
painted surface cannot be sanded. sanding it will sand off the paint.
i think the color you are looking for is pearl white ?
there should be ready-mix pearl white. for spray cans i think choices are pretty limited to mr hobby/tamiya. if you're using airbrush then there should be more paints for you to choose from. iirc mr hobby also have pearl white color in different hue, with a hint of red/green/blue.
simcher
technically, you can sand painted surface, on gloss coating, that's what i do to my cars model....
i sand them after gloss coat to remove "orange peel" surface, and then buff them to shine with polishing compound.
tissuepaper
i didnt know that. but now i know. :s13::o
anyone knows how to deal with this problem? the inner thigh of the gundam will rub against the inner skirt, and the thigh's paint will get chipped. how to prevent this ?? gloss coating ?
bio9205
Hi all - I'm looking to sell my old 00 HGs to modellers who might want them to use for kitbashing... (Not trying to sell them here.) Any advice on what prices these usually sell for? Thanks :) Found a lot of them after CNY spring cleaning. :D
