tissuepaper
usually airbrush comes with the small spanner for unscrewing the nozzle.
try using tweezers to unscrew? if too tight, add a drop of thinner coz it may be because of dried paint
ok i will try this as well. yah came with a spanner that doesnt work :s22: round unscrew round, and the spanner is like few mm wider, hence cant bite into the nozzle
evilerniex
huh :s11:
nozzle usually is small small one mah
maybe can take photo of ur spanner and nozzle and post here
jazy1992
any airbrush expert here ?
my ab doesnt work :( the air is there but no paint/thinner spraying out :(
how to solve ??
I've had the same problem as u a few mths back and what i did initially was soak my nozzle in industrial thinner for 2 hrs which still did not work because the clog was that bad. i gave up and went to order replacement nozzles off taobao.
evilerniex
i had the same problem previously. soak overnight in thinner also no use. so went to buy tool cleaner solution and soaked overnight again. managed to clear the clot.
kenneth0601
Despite industrial thinner being industrial grade, but somehow tool wash is still better when it comes to cleaning air brushes.
Another equipment you guys can use, ultrasonic cleaner. It is about 20-30 quid off TB and it will clean your tools like brand new.
evilerniex
any recommendations for ultrasonic cleaner and where to get? thinking of getting one
Coldhead
Ultrasonic cleaner I bought before from mustafa. Near the car care section at top level. Think about 80 bucks. Taobao cheaper. Lasted me till now 3 yrs. Stripped airbrush n put in a cup with thinner then fill ultrasonic cleaner with water. Feels like new airbrush after that
Sent from LGE LG-H815 using GAGT
evilerniex
sounds good!
shall look out for it the next time i visit mustafa
starsabre
anyone knows where in SG can get a better value (low price) for Gundam Models?
evilerniex
order online from hlj or ami ami usually cheaper. or look out for sales in forum or carousell.
hobby shops here are expensive unless got sales. worst are those dept stores.
starsabre
thank you!..looking for MG OOQ Full Saber....
