simwb90
Oic.. Haha.. Then wait n while waiting.. create space in ur room!!!
Btw.. The SD capsule I m using GP03 stamen.. :D
nice~ i personally dun like stamen with its 2 bazooka thgy on the shoulder...tats y never really try to get it....i usually go for suits with swords....Red Frame, Cgue, Gouf, etc....jus like the designs better =p
Spector1986
I have red frame too..
I like the special attack of rf..
But stamen special can attack AOE..
ongkh2000
Hobbypoint i thought they moved out liao? Bhg no have. Taka i nt sure, gt time go their see see look look
huh? you hear from who sia? hoby point at jec moved out years ago, bt the other branches are still around..
u know, by googling 'hobby point' you can find out about where their other branches are.
osirisx
got a kwestion...
if a kit is flat topcoated(uvcut), do you need to remove the existing layer of flatcoat if intend to gloss coat the kit(coz I intend to change the flatcoat to glosscoat)
duno if I just spray the glosscoat over the flatcoat will it be "duller" compared to normal glosscoat
rookierocky
my mistake i check liao, is the kovan branch only....
rookierocky
got a kwestion...
lets hope our uv cut coated gundam wont turn yellow over time :o
simwb90
keep away from sunlight roh...
not sure if painted kits will turn yellow:look:
if still turn yellow then need to repaint :s27:
if im not wrong...painting it would make it less likely to become yellow barhs....cuz the paint serves as a layer of protection....unless the paint itself is vulnerable to uv lorz....usually not though
