AikiBoy
actually imo... i dont recommend that SF base you use for MG SF... very tall and weak support...:s13: wing too heavy to do the full burst action using the stand also.
sliver0503
hi guys,
just completed this recently
more completed pics can be found here
sliver0503
is that black or navy blue? im not sure whether to paint my Banshee black or navy blue...the obvious colour seems to be black but jus wan a second opinion~
for this banshee, i am using dark mica blue, matt black, grey, gold and chrome
simwb90
is it possible to achieve dark mica blue using handpaints? i dun think it's a readily available colour right?
if yes, mind sharing the required ratio? unless of course, it's on the manual then i'll try and translate the manual~ ^^
HeeroYuy
He used spray cans, but can try using blue as base, black to darken up, and some pearl powder for the metallic effect.
AikiBoy
is it only me or other also...
it seem that its takes max 2 cans of tamiya matt white for 1 gundam...
used rg freedom's leg armors only and almost 1/2 gone :s27:
HeeroYuy
Wah so much meh? Mg? Or hg. If mg n the unit mostly white or use as primer ya.
Dun have to spray tat much, light coat will do, den topcoat
Cleaver
U any how zhua ah? Even London weight .... I mean rj, i use for 2 mg still have alot left ....
AikiBoy
Tamiya matt white cannot anyhow zhua wan... will got bubble forming easily.. must layer by layer.
HeeroYuy
u zhua too much le, can see yur panel lines from yur old kits, mostly all gone. Or u dun like panel lines?
