theclerksays
- Nov 13, 2011
check whether there are paint accumulating at the tip of the airbrush. if there are, it could be due to damaged o-ring or nozzle not tightened properly. damaged needle is also a possible cause.
the splattering is just paint or got water? if got water then is coz too humid liao.
thanks for your help
yes there was paint accumulating at the tip. when I press the trigger down without pulling back, there was paint spitting. I just tightened the o-ring after your post.
I will try again tomorrow and update my findings...
