lalalalalala
- Dec 25, 2005
do you know how difficult it is for brakes to fail? even if your car uses electronic brake the fallback is always a hydraulic linkage from your brake pedal to the brake caliper clamping on the rotor.Why nobody suspect it was the car's braking system faulty?![]()
unless you tell me someone go deliberately cut the brake lines at which point you won't be travelling at that kind of speed on the rightmost lane, because you'd notice it almost immediately at any stop light or on normal roads outside the expressway. even if you so heng to green light all the way from your parking lot to the expressway without braking, you'll be trying to shift to the shoulder and slow down by rubbing against the guide rail. also this is a porsche, i'm very sure there are gear controls to engine brake via paddle shift
