GX70 3BE Dual Graphics problem. Help?
trollandroll
I can't seem to enable Dual graphics (Hybrid Crossfire) on my laptop and I need some help.
Specs:
CPU : AMD A10-5750M
GPU : HD 8970M
RAM : 8 GB DDR3
OS : Windows 8 64 bit
Hailgod
This might sound stupid but, do you mind explaining to me?
The 8970 is way superior to the a10 integrated graphics card. Only a card that is similar performance to the a10's can crossfire with it. Its already so good why u even bother to crossfire?
trollandroll
Because it is kinda lagging on Crysis 3 Medium settings. Btw it is "Hybrid CrossfireX" or 'ATI Hybrid Graphics'.
It is APU + GPU dual graphics
Hailgod
which doesn't work. it works with maybe r7 250m but not a powerful gpu like 8970m
86technie
You have brought the wrong gaming machine as
the AMD APU is not a high end cpu.
Try lowering your resolution and try again.
There's no Dual graphic as the Radeon 8970 does not support
crossfire with the intergraded graphic.
If you just brought this, I would recommend you try to
go back to the shop and change to another model.
The salesperson might have psycho you with the crossfire
which in fact there isn't.
Try to tell this to their face and they might accept or
otherwise check with Corbell and see whether can change or not.
86technie
I bet its a cpu bottleneck in crysis 3. That apu sucks.
That APU is meant for normal use and light gaming but does not
fall under Intel i5/i7 performance.
I wouldn't say it sucks as if you look at price point, AMD
still give you a buck for bang.
I just brought Asus X550DP AMD A10-5750M
but with AMD Radeon HD 8670M for $899.
This model crossfire/dual graphic is supported, I haven't benchmark
it yet as currently I'm having some issues with Windows 8
installation.
If anyone interested, do look out for my mini review.
Hailgod
installation.
Thats why i said it sucks. He bought a laptop with a 8970m and a **** cpu. At least give him an i5 4200m.
hengheng220
Should I feel stupid for buying GX70? Because I seriously don't know how to feel now:(
dont regret la any hardware long liao will also become outdated and cannot support high graphic games. hahahaha enjoy the ability to run graphic intensive games like crysis 3 at mid settings ba mine can't even unless i running on my desktop
emcsquared
we have the same laptop and mine is ok. just make sure you enable turbo clock on your laptop. if you are not yet satisfied with the performance you can use bar-edit.
just search youtube with bar edit
-russian guy doing the guide and his tutorial is quite straight forward.
Link > MSI GX 60/70 - 3.2GHz Clock Speed - YouTube
it will basically lock your clockspeed to 3.2 which would give you decent perf.
