Hard disk sound from drive
LesterQ
Hi ,
Anyone here experience when Heavy writing or reading the drive become Super loud.
Moderate writing/reading of drive the sound is intermittent....
:(:( Beh tahan already
Do they have any diagnostics test?
Kindovic
Hi ,
wat brand???
jtjt00
TS, I think your HDD is going up lorry.
Backup your data as soon as possible.
jtjt00
Use HDTune to check Health tab as well as run Scan (uncheck quick scan).
Louisloo
Hi ,
Either the magnetic heads of your disk are gettng weaker or the heads have loosen. The scratching sounds you are hearing are the heads taking extra efforts to read and write resulting in the loud scratching noise. If the magnetic heads have become loosen, it will tend to stick to the platter as they are reading or writing, thus causing friction and the noise.
Doing diagnostic tests will not make the problem go away, but wlll aggravate the problem and may cause your disk to be totally unreadable.
Better copy out your important data and RMA or throw away this disk.
