Harddisk from Old PC into Portable Case
skinergy
Hi,
I have a old DIY PC which have some windows file error and unable to start Windows properly. However I just need the files inside the harddisk, is it accessible if I just buy a portable casing and stick the harddisk drive in and I can access the files?
Any idea? Dont want to waste money on a casing when the OS is not even accessible/corrupted.
If it is accessible if I install it into the harddisk enclosure, any recommendations? I am using a WD Digital Cavier Green 1TB hard disk.
Thanks in advance!
jtjt00
If you got another desktop, plug into sata port to access as secondary drive.
skinergy
Thanks for the reply, unfortunately I am now using laptop, no longer have any desktop to plug into sata as secondary drive.
Guess the only way is to get a hard disk enclosure?
ZrE0_Cha0s
yup. i think u can find the pricing in qoo10 or lazada or SLS pricelist.
