Harddrive transfer speed goes to zero
gabrielkfr
Have a WD mypassport usb 3.0 with files inside, and when I want to transfer it to my desktop it will start at 80mb/s then go down to zero, how can I get the files without formatting/losing the files?
gabrielkfr
I can still transfer small files <1GB in size but larger files few GB go to zero transfer rate after a few seconds
Lastwishes
The drive is failing.
Happened to me before. Get what you can onto another disk first. What I did was to avoid the files that kept going to 0. After you saved what you can, depending on how important the rest of the files are, you can consider data recovery, either DIY (I had decent luck with ddrescue on linux, but even then it's not 100%) or professional (fairly expensive).
ranmaru
you can use crystaldiskinfo to confirm status of hdd.
as mentioned earlier, transfer other files first, leaving those that have issue transferring to the last.
use chkdsk /r in cmd prompt to try repair.
if in luck, should be able to recover the file after the repair.
hg2
Must the WD red, last time repairing my mac in SLS, people come into the shop asking for recovery... own one and vibration is crazy when reading, shows that the dampening is bad or the design flaw of the disks, off-centre alignment.
The more you spin the disk the more it rocks, the more scratches it creates on the read surface and ultimately the whole drive will be gone.
cscs3
Make sure your disk is format to NTFS if you want to transfer large file.
gabrielkfr
Managed to retrieve all my data and then use chkdsk to format, so how can I determine if the drive can still be used or time to throw? IIRC this external drive is about 8 years old model already
jtjt00
Download and use HDTune to scan for bad sectors. Do not tick Quick Scan.
RyoHarusaki
u still dare to use this drive?
just backup and buy a SSD
pay for reliability
i1magic
I use HD Tune.
