Hardware issue? "tututu" sound
Insomni4
Hi bros, im facing this problem here when i play CSGO. It keep having the "tututu" sound every now and then when im playing.. The whole game is jerking, lagging and freezes whenever i move.. I realised the sound comes whenever u press a button. Any idea whats this problem? Helppppps!:(
PC is less than a year with below specs:
OS: Win 7
CPU: i5-4460
MOBO: ASROCK B85M-HDS
RAM: G SKILL RIPJAWS-X 12800/1600MHZ 8GB
GFX: PALIT GTX 750Ti STORMX
SSD: SAMSUNG 850 EVO 120GB (Game is installed in HDD)
PSU: SEASONIC M12II EVO EDT 620W
Goodshot
you should go back to EDMW instead, reformat will fix everything right?
smart ass
TS, turn off sticky keys in your control panel
hello expert , if u wanna find out defect for ur pc or phone whatever devices , izit better to check in a factory default settings ? U didn't even know he got kena virus or not. and its just a suggestion , no need open big fire
MoneyFace =p
Did you set 'Shift' button on your keyboard for in game function? Cos spamming 5 times consecutively will activate accessibility StickyKey.
kingsen
Its your "STICKY KEY" setting. Go to My Computer , search and disable it , should solve your problems.
IF you're still facing this problem , check your language switching key combination (If you enabled it). Mine previously has something to do with Shift button , and it annoys me alot.
Insomni4
Is tututu or didididi sound?
tututu sound.. it will hang and lag when you press longer or multiple times.
i have unchecked all stickykey functions already.. somehow i try to resolve when ingame by pressing ctrl+tab, ctrl+alt etc etc.. these are the functions i set for changing of language.. perhaps this is the issue?
enenyi
Set language to English (US) or English (UK) only. Disable other language inputs and try see if the problem still occurs. I used to have Chinese (Singapore) enabled, then certain in-game key combos switch entire game to Chinese character input.
