seveneleven
- Feb 16, 2016
Hi, i have been facing this problem intermittently and its driving me crazy. This problems only arise after i do the compulsory win 10 update. Posted here because it might be the hardware causing the problems.
Issues:
1. sometimes right after turn on my PC, the PC will hang/lag, unable to select folders/takes long time to select the folder or do any other task, but still able to access the windows button.
2. Unable to use Words or Excel, able to open it, but it will be a white page and you unable to do anything on it.
3. Corsair K70 Lux lighting profile not loading, become the default red profile. When i open CUE, the keyboard being detected is K95 instead of K70, i don't even have a K95 keyboard.
What i have done to try to resolve it:
i had reformat the PC earlier, reinstall win 10, do the compulsory Win 10 creator updates and its ok for awhile. Install back my programs 1 by 1 to monitor if its due to any of the program that its causing the problem. After that the problem comes back and i suspect its the 3rd party Anti Virus (AVAST) cos that's the latest program i install, so i uninstall it and the problem went away for awhile.
Now the problems comes back again.
And i realize whenever it hang/lag (i go to windows update & windows Defender using the search bar ) , coincidentally Win 10 had just install the updates or window defender just install protection updates. Could it be due to that?
Whenever it hangs , i will need to restart a few times by leaving the "Task manager" apps open.
My spec is:
Mother Board : ASUS H97 Pro Gamer
Chip : Intel (R) core i5-4460 CPU @3.2 GHz
Graphic Card : ASUS Nvidia GTX 970 STRIX
RAM : G Skill RipJaws DDR3 16GB
SDD: Samsung Evo 850 500GB (using it for OS)
HDD : WD Black 4 TB
PSU : Seasonic X Series 650W Modular
OS : win 7 professional - then upgrade to Win 10
Do you this its my hardware that its causing the problem? Not compatible with the latest Win 10 compulsory update?
If really no solution then no choice i would have to switch back to Win 7.
Issues:
My spec is:
HDD : WD Black 4 TB
