Haze@SG for iOS
Jirachi
Probably the worst day so far?
I like the weather forecast. But likely solves nothing.
Shutterfly
Hey guys, I’ve added a new feature to Haze@SG that allows users to check air quality readings from local monitoring stations across Singapore.
The data comes from AQICN and AirGradient, including monitoring stations operated by individuals and the community.
Readings are generally updated every 5–10 minutes, provided the stations are online and reporting data.
Just a note that these readings are meant to serve as additional references, especially if you want to get a better idea of the air quality around your neighbourhood. They may differ from official NEA readings due to differences in equipment, location and measurement methods.
Please treat them as a useful guide rather than the absolute truth. 😊
Jirachi
I think AQI CN adds their own measurements to calculate the index. The PM2.5 is the most accurate value across the known sites like NEA, IQAir.
Shutterfly
Are these PM2.5 readings?
AQI. For AQICN, the AQI values are provided directly. For stations from AirGradient, only the PM2.5 readings are provided, so I convert them to AQI using the same method I use for converting the official PM2.5 readings from NEA.
Jirachi
I see, thanks!
Shutterfly
Going to disable 4 Haig Road station for the time being. The value fluctuates wildly. 😄
