HDTV, Digital TV and antenna discussion thread [consolidated]
koreanlover
I got mine at SLT...first level...enter, pass the shop that sells lighting equipt on the right
the balun transformer i bought is this type~ anyway, my diy CD antenna & older version metal coat hanger antenna cant work also~ probably due to my location and low floor unit~ hv to stick to my roof top antenna~ :s22:
Thanks. I bought it from eBay. USD 2.30 for 3pcs. Couldn't find time to go down to SLS/SLT.
dankoo
ok, done that but still can't recv~ i even placed the antenna outside the window~ i done few antenna before, the best i can recv was TVmobile which already decommission~
my only choice left is roof top antenna~ :vijayadmin:
Did you try placing it against concrete wall? It helps the reception
andmic04
Ok, that was few year back, I didn't know if it still selling now.
Btw, thanks for confirming that. :)
Juz some update, manage to get the matching transformer from UF technology. It work with my diy cd case antenna. reception quantity fluctuate between 70-90%. look good!
just a note though, the antenna location is critical in getting good signal. I placed mine near the window.:s12:
tatsit
High Honorary Member
I got one recently from ebay for 60+ buck.
HD Mini DVB-T2 FREEVIEW MPEG4 H.264 USB HDMI RCA STB RECEIVER,T210T2. test and it work well. only thing is that you will need to get an antenna to go with it which currently I am trying to make one :)
does it have RF passthrough? meaning like the video, plug in the co-axle cable, turn to channel 3 to view the converted digital signals?
andmic04
I doubt there is. there is no mention in the spec and also no physical port for the pass through. you could google for the spec as well.
tatsit
i've googled your STB, there is an ANT Out
the thing is this, my Draco STB also has an ANT Out, but when i plug it in, it acts as an antenna rather than a digital to analog converter which is shown here
can you try out your unit, see whether it acts as an external antenna or passthrough
andmic04
Confirmed. It the same signal as per your antenna in. Not a DAC... I suppose there is no device in the market with that feature, at least not from a consumer product i suppose.
tatsit
the Americans have it. but theirs is DTV not DVB
andmic04
It remind me of my old vcr recorder where there is this option to output video from to the Tv either from composite cable or the coxial cable.
I would suspect that the video was of lower resolution and not HD.
anyway, wish you luck in your search!
koreanlover
The connector for my current TV cable (used to be connected to the Starhub box) is like this:
It is a screw-on type.
Is there any converter for this to use with the below transformer?
jskc3617
Yes. Go google "TV antenna connector" and you will see "Image for Tv antenna connector" webpage. Go in and you should see something that fix your need.
Kiwi8
Deluxe Member
kun1he2
Oooh, arrived already?
You'll need something like this:
product_thumb.php
Or a new cable with the respective plugs.
sunsetbay
Moderator
Moderator
might else just get this balun transformer, no need to use adapter and it's $1 only~ :s22:
BlankShot
Digital Channel 8 poor signal
Hello, I have a samsung smart tv at home, but due to some cabling error in the past which will be very hard to fix now (too deep), the wall socket signal for analogue channel 8 is disrupted and channel 8 is almost unwatchable. We used to be able to watch Digital 8 sometimes using the samsung smart tv but always had the 'Weak or no signal' problem.
Now when we tune for digital, no channels show up.
Is there a way to boost the signal through booster or antenna?
Quite clueless with TV stuff.
Thank you
koreanlover
It's ok I can wait.
Actually I have a shorter cable with the right connectors but I don't seem to get good reception.
Must I put the antenna near/outside the window?
I'm staying in Woodlands (High Floor).
Kiwi8
Deluxe Member
It's ok I can wait.
It's hard to say.... the mileage may vary. But in general, better reception can be expected near/outside the window as compared to further inside.
Kiwi8
Deluxe Member
product_thumb.php
The PAL part is male. It's not the one to fit the transformer's end, which is also male.
