HDTV talk - antenna and reception issues [consolidated]
xdivider
I am having Daiyo EU1707 TV antenna.
Reception and TV image is rather ok.
Occassionally there is some time delay and the image would freeze.
Anyone got better TV antenna to recommend?
funke 250 or better..........
gregory_choo
first, you have to make sure that the antenna is powered up. Normally there is a small LED to indicate.
go to tv's signal strength page, then move your antenna around to find places with better signal.
sometimes you have to try both horizontal and vertical configurations.
maxinger
I placed the antenna flat facing the ceiling and now it is working great.
Just to share. TLDR (too long don't read) :)
I have tried both active & passive antennas.
Summary: If antenna can be placed at good/ideal position -- active antenna does not have much advantage over the passive antenna.
The passive antenna I tried is the cheapo $2 type antenna that Gregory (usually) ask people to try first:
https://shopee.sg/5dBi-Freeview-DVB...tv-indoor-hdtv-antennas-i.63652737.1165569887
I bought a K2 DVB-T2 digital TV receiver set top box (STB) -- used by many other people:
https://shopee.sg/Full-HD-1080P-K2-...trial-MPEG4-PVR-Receiver-i.19067988.315325734
My K2 DVB-T2 STB is placed in front of my TV -- which is (actually) not too far away (2-3m) from the window.
The cheapo $2 passive antenna can't view/receive Mediacorp DVB-T2 channels properly -- if placed next to the TV.
The cable length of the cheapo $2 passive antenna is (only) about 1m -- not long enough for me to place the passive antenna at the window.
So I bought a 2m coaxial extension cable:
https://www.lazada.sg/products/2m-m...42.searchlist.list.29.19b21719nJi6L6&search=1
Using the coaxial extension cable, I'm now able to place the cheapo $2 antenna at the window.
To my (pleasant) surprise, when using the cheapo $2 antenna placed at the window, I can receive all Mediacorp DVB-T2 channels properly. Moreover, signal quality of some channels (e.g. Ch 5) can be as high as 90% !!
The point I want to make is that -- if can placed at good/ideal location -- even cheapo $2 antenna can work.
Above correlates to why Gregory (usually) advise people to try the cheapo $2 antenna first.
bookmark priest
Ed.YEO
尋晚於challenger見到一個 draco機頂盒+funke250天線套裝 賣$99。抵唔抵你地去計嘍。。。
(mustafa賣funke250天線$39)
Mng85
Sign... using a funke home 2.0 with amp still cannot get gd signal without putting near window..
octane99
Is anyone having issues with their channel 5 reception? All my other channels are fine(actually sometimes when a lot of moving on screen will kena pixelated), but ch5 is like watching a HD stream on a 56k modem even when the signal strength and quality show full bar. But video is a lot smoother during movie end credits, I guess cos black screen and small text means less data to process?
Using the gahment free new media solutions stb...
I am facing the same problem on my Samsung Qled....It is an intermittent issue, sometimes Ch5 sometimes Ch 8....
Ever raised this issue here before but seems nobody got any solution.
FYI, I stretched my powered antenna all the way out to my balcony...:sad:
moron+genius
Use the signal quality indication 2 find the best spot
gregory_choo
I have a 65x9000E Sony TV..
I use the https://shopee.sg/5dBi-Freeview-DVB...tv-indoor-hdtv-antennas-i.63652737.1165569887 and try to setup the digital channel.
It does not detect any.. I used this antenna on my 55x8500d and have no issue.
So what can I do.. Any expert can help
are the 2 tv placed at the same location? if not, your 55" is placed at a good location and 65" is not, you may need an active antenna for your 65", or use a RF extension cable to bring the antenna to somewhere near the window.
another possible cause is your version of 65x9000E doesn't have dvb t2 receiver (if you bought it from other countries, not from local sony agents).
fumoffuXx
Hi guys need some advice. I stay in a landed property with an existing antenna. Anyway touse the existing antenna to receive signal to the dvb tv2 receiver?
Tia
gregory_choo
Tia
if you can receive CNA in the past, you should be able to use the same antenna for dvb t2 receiver.
