Iandao
- Dec 30, 2000
ASG-1 rev 1.2 is very good in vocal and bass, but treble is decent unless you can EQ your music. 349 SGD, upgradeable to ASG-2 when it is released with some extra money (head-fi says ASG-2 is really really good) although the upgrade process will be quite troublesome.ard 400-500
- Your rig - Galaxy S2
- What type of usage - frequent airplane usage (noise-cancelling)
- File format used in your source - flac and mp3
- Genre of music you listen to - pop and rock
- Headphone / earphone type - closed
- Other requirements - mic, play/volume (good to have), must be durable! (Last headphone broke in 6 months)
- Budget (in figures) - ~$400
Thanks for any recommendations
ATH ANC-9 maybe? Can go stereo to try out.
Inear, AKG K390NC with mic and control (no volume).
Headphones, AKG K480NC + HA450 (comm kit) with mic and control (no volume).
Thanks, will try out ATH and AKG
Does ATH or AKG compatible with android S2?
- Your rig : Samsung galaxy s3/Apple iPod touch
- What type of usage : Music mostly
- File format used in your source : mostly mp3
- Genre of music you listen to : kpop
- Headphone / earphone type : In ear earbuds
- Budget : under $50
Please help recommend!
TIA.
Do you need a microphone function that works with the S3?- Your rig : Samsung galaxy s3/Apple iPod touch
TIA.
TIA.
It is very difficult to get 3rd party IEMs that has mic and volume control to work with HTCs.
You may want to checkout the AKG K390NC. With inline mic but no volume control and not wireless.
You can try out the Astello Radiance and also the Dunu Trident which is slightly over $50![]()
AKG K390NC confirm can work with my htc one? where to find it?
- Your rig : iPhone, PC
- What type of usage : Mostly Music, Occasional Gaming
- File format used in your source : MP3, rarely others
- Genre of music you listen to : Most varied genres and languages of Metal, Rock, Pop, Ballad
- Headphone / earphone type : IEM
- Other requirements : None
- Budget : $200 (UPDATED)
VSonic GR07. Very good all rounder, not bass heavy but still has good quality bass for the price.- Your rig (iPad2, Ultrabook)
- What type of usage (music)
- File format used in your source (i.e. flac, mp3 etc)
- Genre of music you listen to (big band jazz, jazz vocals)
- Headphone / earphone type (IEM)
- Other requirements (if any) (no other requiremnt)
- Budget ($150-$200)
I don't quite like strong bass. Any recommendation?
- Your rig : iPhone 4 & FiiO E6 amp with FiiO L9 LoD.
- What type of usage : Purely music
- File format used in your source : mp3(iPhone).
- Genre of music you listen to : Koop
- Other requirements : volume control will be good but not compulsory. Looking for a balanced IEM.
- Budget : Below $100.
I currently have a custom tf10 and Dunu trident. I just need another IEM for use on the go and in school. The Dunu trident is too bass heavy for me and sometimes will have a headache listening to it for too long. Also I'm looking for a PMP for use and able to support lossless files. Budget for PMP is also below $100.
\- Your rig : PC
- What type of usage : Gaming/Music
- File format used in your source : Mp3
- Genre of music you listen to : DnB, Techno, Rock
- Headphone / earphone type : What does this mean?
- Other requirements (if any) : Mic, $120 budget.
Very sorry for the late reply,
Would like to thank kaltzbalger and anyone else who helped me by giving advices a few days ago. I have been poisoned after doing more research on IEM's, and will increase my budget to $200.
Would like to know which of these are better,
Yamaha EPH-100, Shure SE215, VSonic GR07, Atrios Mg7
If I have missed out any other good IEM's around my budget, please do feel free to recommend and advice.
Currently leaning towards the EPH-100.
I will quote my previous post but updated.
