Help a first time builder. Need advices/comments/enlightenment
denurhelal
Hi bros,
i'm thinking of building a mid range gaming desktop.
Doing some work and school stuffs with it too.
Games intend to play (weekend gaming): Battlefield 1, Payday 2, Skyrim
Budget: 1K-1.2K
Wifi: required
OS: required
Here are the parts that i compiled after walking around SLS and taking all the brochures available.
CPU+MOBO: MSI B150A Gaming Pro + i3 6100
RAM: Kingston 2133MHz
HDD: Toshiba 1TB 7200RPM
GPU: Zotac GTX1050 mini 2gb
PSU: CM Elite V2 550W
Case: Corasair Carbide Spec 2 (b'coz its sachok)
Is i3 6100 enough to play the latest gen games?
Pls help me out and comment on the general parts that i had in mind. TIA!
Koenig168
RAM - You will need at least 8GB of RAM.
HDD - I would suggest WD Blue 1 TB. Make sure you get the 7,200 rpm version and not the 5,400 rpm version.
GPU - GTX 1060 3 GB would be better value for money than GTX 1050.
SSD - You will need a SSD for the OS and some programs. 240GB is preferable but 120GB will also do if you are on a tight budget.
Do follow the Lazada and Qoo10 threads for good deals, which can stretch your budget quite a bit.
MianBaoFren
no. the i3 6100 is decent but if u are playing anything that requires more cpu processing, it won't do. u need a i5 6400 at the very least.
up a notch and get the gtx 1060 3gb at the very least. gtx 1050ti prices in sg is pretty bad. don't bother looking if u are gaming.
consider a more budget psu like the fsp hexa 550w. if u are going for 1060, a 450w psu will do but it's entirely up to u.
casing i dunno much but get something that's easier to cable manage. and leave casing to the last. u dun want something that looks nice but with crappy parts.
oh and grab a ssd at the very least. at least a 240gb although i would tell u to push for a 480gb.
will u be comfortable with diy and buying parts online yourself to assemble? u could save even more money and get more performance out of your rig.
intrance
Hi bros,
Can elaborate.. what type of 'some work' and 'school stuffs'?
if it like video/photo editing, producing 2D/3D.. dont skimp on your CPU..
denurhelal
thanks, ill change my cpu to an i5 6400, gpu to gtx 1060 and psu to fsp hexa 550W
how abt the MOBO? isit good?
ZrE0_Cha0s
just basic photo and video editing
if basic best at least have a i5. though 6400 is alright but for another 20 bucks u have more clockspeed as well might as well get 6500?
and this also a plus for the games u playing ;)
MianBaoFren
mobo if u want inbuilt wifi can consider the pro gaming wifi aura b150. also, what monitor are u using atm?
MianBaoFren
monitor have yet to choose. Hahaha! totally a beginner in pc games actually.
well u need a budget to start with. for pple who more into fps, 144hz monitors can be very good. if u just play games like dota etc, a normal 1080p monitor @ 60hz will do.
MianBaoFren
any 144hz monitors to intro?
i heard for budget, can consider the qnix ones. they are around $200+ on qoo10 if i remember correctly.
i went for the zowie xl2411. it's 1080p @ 144hz which is really enough for me.
mamalemons
Thanks man, will take a look at your recommendations:s12:
