Help! Advice on gaming rig! :)
irfaanvex
Hey all, i have a budget of 1k - 1.2k and building rig to play games such as dota and cs go. If possible, can include os and monitor in the budget? I'm also thinking of including an ssd? I'm a complete noob here haha. Oh and i also need a wifi card for the rig. Appreciate the suggestions and help everyone :)
Alternative X
CPU+ Mobo: ASROCK H81M-HDS + i3 4150 (225)
RAM: G.SKILL PC 12800/1600MHZ DDR3 CL11 VALUE RAM (8GB) (102)
GPU: LEADTEK GTX 750 2GB O.C (188)
SSD: ADATA SP900 128GB (99)
HDD: TOSHIBA 1TB 7200RPM (69)
DVD-RW: LG 24X DVD-RW SATA OEM (25)
PSU: SEASONIC S12II-Non MODULAR 520W (85)
Case: CM 311 ATX CASE (50)
OS: WINDOWS 7 HOME PREM (120)
Monitor: AOC 24" e2461Fwh (219)
Networking: ASUS PCE-N15 (59)
Total cost: $1241
Buy at PC Themes, #04-15, and ask for discounts. DIY yourself. If you can't into DIY, pay $30 for assembly by PC Themes.
irfaanvex
Total cost: $1241
hey, thanks a lot! quick question tho, would it be advisable for me to go for a i5 instead? as i would hope this rig would last me a good 5 years haha thanks again
Alternative X
If you want to make your rig last longer, then get an i5 for another $90.
Alternative X
would i still be sticking with the same mobo if i change to an i5? or do i need to get another mobo? thanks in adv :)
All these motherboards are Socket 1150, the H81M-HDS can even run an i7 if you wish to. Just stick with the same motherboard since your budget is tight.
E_G_G_S
you can consider b85 motherboards. h81 motherboards do not support usb 3.0 slots for the front of your casing. can also consider getting a SilverStone PS 08 case since you are getting a mATX motherboard, it's smaller and better and only cost $9 more than the CM 311.
nippp0n
CPU & Mobo: i5-4460 & MSI B85M-G43 @ $336
Ram: Crucial 1600mhz value ram 8GB @ $100
ODD: Samsung DVD RW @ $21
SSD: Plextor M6S 128GB @ $104
HDD: WD Blue 1TB @ $68
GPU & Case: Palit GTX 750 Ti & Asgard XP @ $248
PSU: Seasonic S12G 520W @ $85
OS: Windows 7 Home 64bit OEM @ $115
Monitor: Dell S2340L @ $198
Total: $1275
Buy from Tradepac and DIY.
E_G_G_S
CPU+MB - MSI B85M-G43 + i5 - 4460 - $357
RAM - G.SKILL RIPJAWSX 1600MHz CL9 (4GBX2) - $117
SSD - PLEXTOR 128GB M6S - $104
HDD - WESTERN DIGITAL 1TB BLUE - $67.50
GPU - ZOTAC GTX750TI 2GB DDR5 - $218
PSU - CORSAIR CX430M 80+ BRONZE - $60
CASE - SILVERSTONE PS08B - $59
OS - WINDOWS 7 HOME PREM 64 BIT OEM - $115
MONITOR - DELL S2340L - $198
WIRELESS - ASUS PCE-N15 - $59
Total Estimate - $1354.5
Ask for quote at Tradepac, level #05-18.
Bring this list to them without the prices and ask them for quote, they can quote you lower than this. Ask for discount.
Bring the parts to PC Care & Solutions, #02-32. Look for Nigel and give him $20-30 assembly fee to help you assemble.
irfaanvex
alright man, thanks for the advice! will be confirming my rig in the coming weeks :)
just out of curiosity, what would i need to get/upgrade if i want to get better performances for my games?
Alternative X
A GPU upgrade is the fastest way to improve gaming performance.
