[Help] Audio Jack Repair
haodede
Suspended
Hi,
My headphone jack is facing some problem, I need to bend the wire to specific a angle in order for it to work.
Can anyone recommend me a shop to get it repaired ? I am heading down to Sim Lim Square today.
Thanks ! :yawn:
bobby29
can try Stereo, last time my earphone got the same problem also got them to fix it.
ckryan3
sim lim square 2nd floor, there's a shop called "AVIT", they do retermination.
3rd floor, got another shop, but forgot what it's called...
sim lim tower, almost all the shops will do retermination
FatalethaL
AUVEC, if i rmb correctly.
ckryan3
Ahh, that's what it's called....yeah, that sounds abt right, haha
The replacement 3.5mm jack shld be about $5, reterimination fee is between $15 to $30, depending on where u go.
AVIT is $15 i think, but their workmanship not exactly top notch (they don't heatshrink it to prevent it from breaking)
AUVEC is $20 or $25, but they heatshrink it and all that
kazuki666
TS, dun mind me hijacking your thread.
when u say audio jack, are we talking abt this?
coz I have an earphone this part is loose, and sound is "losing" and it will come back when I twist and turn it.
if we talking abt the same thing :) , which shop will u all recommend for quality worksmanship? will be great if u know the price too ;)
cheers
porcu
Stereo is a good place but their L-shaped audio Jack kinda heavy. :D
Crustaceanzx
I went to "Rison Radio & Electric Co." At sim lim tower #02-30 to repair my westone w4. My w4 cable got loosen near the earpiece end. Usually most of the stores at sim lim tower don't want to fix this type of issue.
However, the uncle at the store is very professional at cable retermination. He can do it quite fast and very neatly! Totally recommended!
redsuns86
Care to share how much was it?
Thanks!
