[help] black screen with 100% gpu fan
jkohlc2
been getting this issue lately, use PC halfway (gaming or web browsing or idling), monitor will lose signal and gpu fans will go to 100%
if i press reset button, system will reboot with 1 long beep and 2 short beep (MSI manual says is VGA fault)
is my motherboard dying? or suay suay 2 GPU faulty?
motherboard: MSI B450 Tomahawk Max on latest bios
OS: Windows 10
CPU: AMD Ryzen 5900X
GPU: AMD 5700 XT and Nvidia GTX 1060
PSU: 850W
steps taken:
  • replaced cmos battery
  • tested on 2 different gpu, both had same issue
  • tested on 2 different PSU, both had same issue
Dis2012
OS: Windows 10
PSU: 850W
steps taken:
1) Flash to Latest Bios
2) Download latest Chipset Drivers and GPU drivers
How come u using 2x GPU?
3) Try single GPU
86technie
Can be driver conflict especially AMD and Nvidia.
Before updating/uninstall previous driver by disconnecting from internet.
Than install the latest graphic card driver.
Which power supply are you using? Could be PSU issue.
For AMD RX5700 recommend use two separate PCI cable but not piggyback which is on 1 cable.
Before you change graphic card, reset the PSU by flipping the switch 5 times.
*Disconnect the power cord before resetting the PSU.
To me I suspect PSU issue especially if it is very old PSU.
My rig lately also have similar issue, during gaming it will switch off.
Went to RMA the PSU and the PC is working fine.
jkohlc2
How is it that you are using 2 different brand gpus?
3) Try single GPU
Paiseh for confusion, i tested with 2 separate gpus
Test with 5700 XT, black screen and 100% fans after few minutes
Boot to safe mode, ran DDU, shut down and swap to GTX 1060 and install nvidia drivers
Same thing, black screen and 100% fans after few minutes
Read HWZ Forum Rules!
ronnie_gogs
Might be a RAM issue as well. Try with one module only and at every slot. B450 Toamhawk is a AMI bios if I am correct. The 1 long 2 short according to different website means video card memory issue.
https://www.computerhope.com/beep.htm#ami
  • Try single ram in different slots
  • Different PCIex lane
  • Do have overclocking software installed like MSI Afterburner. You can try lowering the GPU memory clock.
