Help build a gaming rig ~1.7k
reky1989
Hi everyone,
My current rig is reaching 10years soon. I have been doing my own research and have a few ideas on my own. Would appreciate if i could get more inputs.
Budget is around 1.7k sgd for the tower and OS. I have monitors and kb +mouse.
I'm looking at rx580 instead of 1060 6gb so i can use a cheaper freesync 1440p monitor in the future. Ram would be 16gb.
I'm having trouble deciding on the CPU processor to use. Please help!
pedokuma
You did your own research and have a few ideas. Post those ideas /parts for people to start with...
iicecube
i will start something decent to mark it, a decent build with 2600
Amd 2600 ==
MOBO:
GIGABYTE X470 Aorus Ultra Gaming ==
MSI X470-Gaming-Plus ==
CORSAIR Vengeance LPX 2400 C14 ==
G.Skill RipJawsV 2400 C15 ===
PSU: $100-120 range
Hard Drive:
Samsung 860 EVO 250GB local 5yrs SATA3
SanDisk SSD Plus 240GB local 3yrs SATA3
Case: Sharkoon TG5 Tempered Glass $105 (Come with 4 fans)
Total: $950-$1050
Window 10 home 64bit == $130-150
GPU: $450-$550 Depend on 1060 or RX580
950 to 1050 without OS/GPU/cpu cooler and if wanna save up the case fans.. Your 1.7k can only do this decent buildup unless you can grab used GPU to save up something..
~~~ If you going intel road, getting 8400 was the compare you getting but alittle higher cost if you choose a decent mobo.. (mobo as in not those 100-150 buck kinds)
ZrE0_Cha0s
Ern...maybe u can tell us what you want to do with your PC? Gaming, work, etc?
