help build CPU for Game
jamestanws
Hi please advise on the spec needed to bulit a CPU for NBA2K17.
the smaller and cheaper the CPU the better.
only CPU require.
thanks
MianBaoFren
errm by cpu definition u mean only the CPU (i3,i5,i7) or the entire thing? i am assuming the latter.
u can't say that the cheaper the better. u need graphics expectation, budget, whether u need wifi etc.
what monitor are u using? do u need a joypad or playing with keyboard? need more specifics.
jamestanws
thanks for the reply. is below 800 possible? using keyboard to game nba2k only. using monitor. please advise
MianBaoFren
jamestanws
I think it's doable. It's about expectations and how long before the PC gets outdated against future games.
Just a few more questions:
Do u need Wi-Fi? Or are u using lan cables?
What resolution is your monitor?
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
yes will need wifi and using my 26inch full hd tv as monitor. hope to keep my cost low and cpu unit small as possible. or should i look at those 799 or 899 dollar cpu unit that sold on courts challaneger.
thank you.
MianBaoFren
i3 6100 + asus H110M A - 279 (pcthemes)
Crucial 8GB DDR4 - 55 (pcthemes)
Palit GTX1060 3GB - 270 (lazada)*243 after discount
FSP Hexa+ 450W - 58 (pcthemes)
Tecware F3 - 39 (lazada)*35.1
Crucial MX300 275GB SSD - 112 (lazada)*100.8 after discount
Total: $770.9
this can be done if u build it urself. u might have to fork abit extra for the OS.
ZrE0_Cha0s
MSI H110i PRO AC + i3 6100 @296
Crucial 2133Mhz 8GB @55
Palit GeForce GTX 1060 Dual 3GB @270^ (Lazda SG)
OCZ Trion 240GB @98
Sliverstone SG-05 @65 (Comes with 300W PSU)
Total: 784
all prices quote from PCThemes, otherwise stated.
lazada price include free shipping
^pay using lazada app and use this code at the payment : KAISOO (10%, max $30)
MianBaoFren
Palit GeForce GTX 1060 Dual 3GB @299^ (Lazda SG)
OCZ Trion 240GB @98
Total: 810
will the 300w psu be enough? i went to see and the recommended for gtx 1060 is like 400 sia. and yea, that mobo is better than the one i recommended.
ZrE0_Cha0s
well that one they give a bit of leeway with gpu and i5 or i7 OC verison would really need that many, but i3 and with those parts + gpu shouldn't use up to 250w, maybe max 230w.
MoneyFace =p
Petite and powerful enough.....
CPU+MB: Intel Core i3-6100 + MSI H110i Pro AC @ $296
RAM: Crucial DDR4-2133 CL15 8GB @ $55
GPU: Palit GTX 750 2GB StormX OC @ $109* (Lazada SG)
NBA 2K17 is a low end, little demanding game series.
SSD: Crucial MX300 275GB @ $101^ (Lazada SG)
CASE+PSU: In Win BK644 + Powerman IP-P300BN7-2 300W SFX [80 Plus] @ $99 (Laser Distributor)
Only 12.5 litres, smaller than many mITX chassis!
GPU height clearance shouldn't be an issue.
http://detail.zol.com.cn/picture_index_478/index4773848.shtml
Power consumption definitely not an issue with its 300W SFX PSU.
Total: $660
Optional:
OS: Microsoft Windows 10 Education 64-bit Product Key @ $28 (Reddit)
Check buyers' review first.
Buy others from PC Themes, #04-15.
*Price after Lazada App Maybank Wednesday MBHW16 / DBS FriYAY APPYAYS / CITIBank Wild Weekend CITIWILD 15% off max $20 discount (for new customers)
Use this first to avoid nullification.
^Price after Lazada App Maybank Wednesday MBHW16 / DBS FriYAY APPYAYS / CITIBank Wild Weekend CITIWILD 10% off max $20 discount (for existing customers)
