[Help] building a budget web browsing pc.
HappyLee
Hi guys, I'm currently looking to build a budget web surfing desktop for my girlfriend but I'm not really sure what parts to be getting. I hope the seniors here would help me out, main usage would be web browsing, and streaming of videos.
Thanks in advance!
HappyLee
Is it comparable value for money wise to custom cpu? I remember years back there wasn't much cheaper option as pre-built pc sucks like ****.
gld998
Die die must use ssd for primary drive. 120gb just for os and office. then get 1tb for storage plus external drive (2tb and above) for photos etc. Should be good enuf. Core 2 duo also ok. Doesnt make a difference to them. I am living with drama addict as well.
tmfwy
Thanks in advance!
Get a NUC
8gb Ram
SSD 120 - 256gb whatever you want
1TB HDD
THe most important thing
It must be able to surf Qoo PROPERLY without LAG
It must run smoothly without issues
And preferably play light games easily ( in case she suddenly want to lay Sims )
Stick all of it behind a monitor.
tmfwy
C2D cannot la...
It is noisy...
I threw away Android boxes coz wifey complains of LAG when she surfs Qoo.
Hence the benchmark
IT MUST surf Qoo Properly..
MoneyFace =p
C2D cannot la...
It is noisy...
Hence the benchmark
Core 2 Duo can de... SSD is the one that makes all the differences..
HappyLee
I went to check nuc and saw different unit, it's all diff specs?
Viper0402
Agree...
C2D E8400 for the 3 kids, 4gb ram, WD Velociraptor 150GB 10kRPM HDD, MSI Radeon HD7870 2GB OC, for all their schoolwork and surfing internet with IE, Chrome, Firefox no problem...
MoneyFace =p
Thanks in advance!
This will makes a total fluid, quietest, sleekest PC for your bae.
CPU: Intel Pentium G4560 @ $106*
MB+WIFI+BT: ASRock H110M-ITX/ac @ $99*
RAM: Kingston ValueRAM DDR4-2133 CL16 4GB @ $39^
SSD: Samsung SSD 850 EVO 250GB @ $119*
CASE+PSU: In Win CHOPIN + Integrated 150W [80 Plus Bronze] @ $130*
Refer below for illustration. Best for Apple product lovers.
OS: Microsoft Windows 10 Pro 64-bit [Product Key] @ ~$2 (Taobao)
Do a search "win激活"
Total: $495
Prices from Lazada SG listings unless otherwise specified.
*Prices after 20% off $100 Singtel Online/Wogi Lazada Gift Card purchases [Available to use from 11/11/17 0000 HRS].
^Prices after 40% max $15 off Lazada 11.11 voucher grab [Available to grab from 11/11/17 0000 HRS].
HappyLee
Do a search "win激活"
Total: $495
Prices fromLazada SG listings unless otherwise specified.
Thanks for the recommendation, do you think it's possible to play games like The Sims with integrated graphics?
Irenicus
The FPS for The Sims 4 is after the user installed a GTX1050 Ti in his system. For the integrated graphics, the user did not provide the FPS for The Sims 4.
Please read through the link carefully.
Hailgod
Nope you should open your eyes bigger and read the entire article properly. Not just head and tail. :s22:
Never mind i will read it for you:
you see wrong eh.
With the 1050Ti installed:
Battlefield 1: 47fps (1080p, Advanced graphics setting in this order: High, High, Med, Med, Med, Med, High, High, DX12 off, FPS limit 60)
World of Tanks: 61fps+ (1080p, Maxed out, V-Sync on)
Dirty Bomb: 61fps+ (1080p, Maxed out, V-sync on)
Stranded Deep:45-61fps+ (1080p, Maxed out, V-sync off)
Need For Speed MW: 100+fps (The old game not the modern one, Maxed out)
Need For Speed Shift: 78-224fps (Maxed out, V-sync off)
COD MW1: 61fps+ (Maxed out, V-sync on)
Istrolid: 100fps+ (There aren't graphics options)
PayDay 2: 48-61fps+ (Maxed out, V-sync off)
Rocket League: 90+fps (Maxed out, V-sync off)
Fortnite: 50-90fps (Maxed out, V-sync off)
Borderlands 2: 70-130fps (Max settings, V-sync off)
Saints Row IV: 100+fps (Maxed out, V-sync off)
Outlast: 200+fps (Maxed out)
Brink: 100+fps (Maxed out, V-sync off)
The Sims 4: 54-164fps (Maxed out, V-sync off)
