[HELP] Building a gaming rig ~$1k
Oxidezero
Hi bros, been wanting to build a relatively cheap gaming rig for a while now but I decided to seek your expert opinions first. It'll mainly be for gaming and everyday stuff like movies and downloads. Planning to run games like Dota2, FFXIV, Battlefield 4 on max settings..
NOTE: Budget does not include monitor, OS and peripherals
Parts I've narrowed down to:
Asrock B75M-DGS + i5-3470 (Should I go Haswell?)
GTX650 TiBoost DCII 2GB or GTX660 (Asus, MSI, Palit, Gigabyte? Not sure)
WD Caviar Blue/Black 1TB (Read that the black is more reliable)
Corsair Vengeance 1600MHz (2x4GB)
Random dvd disk drive
Sharkoon T28 casing
Seasonic S12II 620W Bronze
Others not included in budget:
DELL U2312HM
Keyboard
OS
SSD (to be added in the future)
Is there any significant feature people look for in the mobo? Cause it has usb3.0 and an integrated sound card, graphics and I don't think I need anything else.. Also, guy told me that the GTX650 TiBoost is almost on par with the GTX660 so not worth paying the extra $$$. If anyone has a better 'bang for buck' recommendation, do feel free to tell me! Open to suggestions, thanks :)
Clone_
HD7850 is better than 650 Ti, can be cheaper or same price depending on which brand you wanted to get for the 650 Ti
royfrosty
Sharkoon T28 casing
DELL U2312HM
Keyboard
OS
Yes gtx650ti boost almost on par with gtx660. But what that guy tell you is rubbish on the extra money. A gtx650ti boost already reached its chip peak performance. A gtx660 has a better performance.
Furthermore considere getting another type of rams. Ram have shot up above $100.
For your budget 1k without os monitor and other peripheral.
Asrock b75m dgs + i5-3470 ~ $292
Kingston value ram 8gb ~ $90
WD blue 1tb ~ $81
Palit gtx760 2gb + fsp 550w raider~ $399
Samsung odd ~ $21
Sharkoon t28 ~ $87
Total $972. Buy at tradepac. Diy.
Can opt for nzxt h230 for its look. But no side window panel. Additional $20 to your grand total.
Oxidezero
WD blue 1tb ~ $81
Palit gtx760 2gb + seasonic m12ii 620w ~ $399
Samsung odd ~ $21
Sharkoon t28 ~ $87
Looks like a great deal considering its gtx760 but I've heard that Palit's get really noisy under heavy usage though. Can anyone confirm this or have another recommendation?
royfrosty
Is not noisy. I'm using mine at 65% fan load. No noise is noticeable. Once adjust to 75% can hear a bit of noise. Of cause at 100% it sounds like a chopper. But I doubt you will go till 100%.
If you so scared of the fan noise can get the MSI twin frozr edition.
Honda_
You set at 65% or auto?
royfrosty
Why do you set it at 65%? So it's running 65% all the time?
Cause when it is running at auto fan speed will not go that high one lol. Max 48% playing bf3 on ultra and AA 4x load temp 72 degrees. With manual fan speed increased to 65% I get 64 degrees. Way much cooler. The program by palit auto rpm wont go more than 50% fan speed.
Oxidezero
Hi bros, making my pc this weekend so here are the final parts I've narrowed down to, just wanted to confirm :D
Budget:~$1050
Parts:
Asrock B75M-DGS + i5-3470 ~$292 OR
ASUS H61M-A USB 3.0 + i5-3470 ~$290
MSI GTX760 TF Gaming 2GB OC ~$409 OR
Gigabyte GTX760 2GB OC N760OC rev 1.0 ~$409
WD Caviar Blue 1 TB ~$80 OR
Plextor M5S 128GB ~$139
PC3 1600 G-Skill RipJawX Kit CL9 (4GB*2) ~$105 OR
Kingston ValueRam (4GB*2) ~$90
Sharkoon T28 casing ~$86 OR
Sharkoon T5 ~$68
Seasonic S12II 520W ~$89 OR
Corsair VS Series 550W ~$75 OR
CM Extreme 625W ~$85
Random disk drive ~$20
Total: ~$1081 (w/o SSD)
~$975 (w/ SSD, ValueRam, 650Ti)
1) Will there be any dual channel compatibility issues if I chose the ValueRams?
2) Better GPU + HDD or Lousier GPU (e.g. 650Ti) + SSD?
3) How much wattage do I really need for my rig to be safe?
Thanks all! :s12:
royfrosty
Budget:~$1050
Parts:
Sharkoon T5 ~$68
Thanks all! :s12:
Don't just use an ssd only. The more you write on your ssd the faster out worn off your ssd. Best is to get both.
But since you got budget constrain then get the HDD will do.
Get a gtx760. And BTW if you are getting from tradepac you could easily save a good sum of money. MSI gtx760 2gb twin frozr + seasonic m12ii 620w ~ $499
Palit gtx760 2gb + fsp raider 550w ~ $399
Gig gtx760 2gb + seasonic m12ii 620w ~ $505
No issues with value ram.
550w is enough.
Avoid cm extreme PSU.
Oxidezero
550w is enough.
Thinking of squeezing in an SSD cause I have a spare 320GB HDD at home. Anyway, thanks for your input Roy but just one last question..
I'm assuming Palit's GTX760 is the non Jetstream version hence, being a whole $100 cheaper than the other bundles. But is the price cut worth it?
royfrosty
Non jetstream is around $359. Fsp raider 550w ~ $58 about $17 savings. Downside palit is 2 years warranty.
If you think you don't mind the warranty period then MSI or giga will be the next available.
