[HELP] Compatibility issue between chassis and graphic card
comtt74
My chassis is COOLERMASTER ELITE 335U RC-335U-KWN1 while my graphic card is MSI N560GTX-M2D1GD5 1GB GDDR5 PCI-E (AFTERBURNER).
I am not able to use the mini HDMI output on the graphic card as the chassis is preventing the cable from securing into the mini HDMI output.
As a result, I am using the DVI ouput.
Is there any chassis that will not have any compatibility issue as mentioned above?
Thanks.
Humster
Don't think there is much to do. Since its a "hard" issue. Its like having my 6970 being too long for my NXZT casing. End up getting a new chassis.
hlots123
if its only very slight difference, hav u tried connecting the mini hdmi connector 1st before tightening the screw tat secures the card to the chasis...?
comtt74
Maybe I will give a try when I reached home.
Never though of it.
Thanks.
