I got a new rig about three months ago.
CPU & Mobo: i5-3470 & Asrock B75 Pro 3M
Ram: G.Skill 1600mhz value ram 2x4GB
ODD: HP 24x DVD-RW
HDD: Western Digital 1TB Blue 64MB
SSD: Plextor M5P 128GB
GPU: Powercolor 7870 Myst
Case: Sharkoon T28 Green
PSU: FSP Raider 550W
Almost a week after, it started to freeze during games especially when playing LOL. It would also freeze randomly on other games like XCom, which is offline.
Then it started to go into Blue Screen.
I brought it back to the shop which I got it from Best Buy. They tested the hardware and said no problems and said I should reinstall Windows.
I did but the problems persisted. I brought back a second time and after testing for two days, they said it was the ram and replaced it.
But guess what, the freezing persisted.
Wanted some advice: If its not the ram, what would cause such problems? I'm thinking its the GPU. Or could it be the Mobo?
I gave up on bringing back to the shop. They are nice guys and I've no problems with them. But this is a problem I really want to fix.
If got advice, appreciate in advance. Open to buying a cheap GPU to test or if got a good independent repair guy, who can get to the bottom of this, am willing to pay. I just want to have a basic functioning machine.
Forgot to add that I've updated all drivers and temp of GPU is within normal range
ODD: HP 24x DVD-RW
