(Help decide) Which build should i get ?
hendacagon97
Option 1:
Intel i3 10100f
Gigabyte H410m H
LEXAR 16Gb RAM DDR4 (8GB X2)
LEXAR m.2 512GB of SSD
Fsp 420W HD 80+ PSU
ZOTAC oc RTX 2060
techware nova m Casing
Windows 10 pro genuine
$1053
Option 2:
RYZEN 5 3600
B450M GIGABYTE CHIPSET
16GB RAM DDR4 (8GB X2)
RTX 2060 6GB GIGABYTE WINDFORCE
500GB NVME SSD
650W BRONZE CERTIFIED PSU
TECWARE NEXUS WITH SIDE TEMPERED GLASS
WINDOWS 10
$1337
My budget is initially $1.3k but i don’t mind going slightly over. However if these 2 gonna perform the same, might as well go for the cheaper option. Help me choose plz
zleipnir
I think should go for option 2.
Ryzen 3600 is 6 core CPU. it's quite the common build for current times.
i3 10100f is only 4 core CPU.
Option 1:
Intel i3 10100f
Gigabyte H410m H
Fsp 420W HD 80+ PSU
ZOTAC oc RTX 2060
$1053
Option 2:
RYZEN 5 3600
500GB NVME SSD
WINDOWS 10
$1337
NightRaven49
Option 1:
Intel i3 10100f
Gigabyte H410m H
Fsp 420W HD 80+ PSU
ZOTAC oc RTX 2060
$1053
Option 2:
RYZEN 5 3600
500GB NVME SSD
WINDOWS 10
$1337
performing the same in what kind of workload? if gaming, the 10100 is okay-ish, given that at 1080p the 3600 is 15% faster but the rig costs 30% more, and that lead diminishes at higher resolutions, which is probably the intention with the 2060. however, if looking to do any kind of productivity, the 2nd build with the 3600 will stomp.
also, where did u get these quoted prices from?
abstrax
Option 1:
Intel i3 10100f
Gigabyte H410m H
Fsp 420W HD 80+ PSU
ZOTAC oc RTX 2060
$1053
Option 2:
RYZEN 5 3600
500GB NVME SSD
WINDOWS 10
$1337
I will get option 1....since not much diff in performance and maybe in another 1 yr of usage u decide to upgrade again....
congster2
To me, the main difference between the options are the upgrade paths.
With option 2, you can upgrade to a second hand 5000 series cpu in the future, and the psu should be able to support a second hand rtx 3070.
Option 1, think you can’t do s**t with it haha..
tsteo77
Option 3.:) Just Joking. Btw you used up all your budget for option 2,
where to find money for monitor, speaker, keyboard, mouse and wifi card ?:s22:
