lindseymin
- Jan 17, 2017
Hi, I need some help with my dell Inspiron 7420 laptop charger. The mini green light isn’t lighting up so I’m guessing it’s dead. Tried using other laptop charger but plug don’t fit.
If I need to buy a replacement, what info on the adapter do I need to check? I see a couple of numbers behind like 90W-AC then input ac 100-240V ~1.5A
And output DC 19.5V = 4.62A
And there is the pin part that connects to the laptop size difference.
Must the values for the new adapter be exactly the same?
