[HELP] Desktop keeps restarting
emiliated
Hello everyone.
My desktop suddenly keep restarting itself. On.. off.. on.. off.. the loop nvr ends.
I tried resitting the ram but it didnt work.
Would appreciate your valuable advices.
Thanks and have a nice day :)
Short clip of the restarting issue:
https://youtube.com/watch?v=0eI8570PCpA
peterchan75
Very high chance PSU failure. If you can get a spare PSU and swap it OR RMA the PSU.
kracie17
It looks like possible power supply failure. Do swap if you have spare and if your current one is still under warranty, do an exchange with the distributor.
zenniz
One component or connection is creating the problem.
Slowly remove 1 component at a time.
Starting from
Storage device
Graphic card
Fans
1 ram stick at a time. Swap the ram stick too
If computer boot properly, it means that the component that you last removed is creating the problem. To confirm, install back and retry it 2~3 times.
Masa27
Had the same exact problem but manage to solve it once I resit all the connections.
tmfwy
Hello everyone.
IF on / off happens at POST stage BEFORE windows
High Chance MOBO FailureN ( but also can be small chance of cpu failure )
Best bet is to diagnose with spare mobo / cpu
Seat only 1x ram
Remove Graphic Card and use internal Grahic Port of Motherboard
Does Computer keep on restarting?
emiliated
Hey bros, thanks for all your advices. Swapped the PSU and it managed to work normally for an hour or so.. thn the problem came back. Will continue to try and troubleshoot...
ZrE0_Cha0s
Tried using other power socket? And make sure u dun mesh all socket into those 3 pins extended plug
jtjt00
Try with 1 piece of ram, swap if still restart. Next will be motherboard.
tmfwy
Then is high chance mobo failure.
You will need access to another mobo to confirm this.
