HELP: DIY CPU recommendations
  • Need someone to talk to?
Renndo
Hi guys
I would like to build a CPU since my current 6yr old quad core cpu is malfunctioning (power supply/graphic card problem. seems to be because of split screens.) I mainly want to use it on 2-3 Split screens (2x17in & 21in) for multitasking of heavy usage of web browsing (e.g. many tabs open at once) and running a movie/shows at the same time. I was hoping i could get some advice on my build.
Graphic card
GTX 960 4gb
(whats the diff with asus and gigabyte?)
(is it enough to handle stress from splitscreen?)
Ram
DDR4 kingston 8gb x 2
Processor
i5 6400 2.7mhz
Storage
HDD - toshiba 1tb 7200
SSD - toshiba 240gb
Case, motherboard and PSU
not too sure on this. recommendations or advice?
Also do you guys know if its possible to trade in my old computer parts? hope to get some help! thanks for reading!
WhiteHunter
you can sell your old computer parts at the marketplace here or carousell.
DawnsTear
What ur 3 monitor input ?
Playing any games ?
Budget ?
Ur SSD & HDD reuse or buying ?
Renndo
Playing any games ?
Budget ?
Thanks white hunter
Dawnstear
Probably not playing any games.
Budget about 1.1 to 1.2k?
Ssd and hdd buying new.
2 is vga. 1 is hdmi/vga
DawnsTear
[Mobo&Proc] Gigabyte B150M-D3H /w i5-6400 - $428.00
[GPU] Zotac GTX 750 Ti 2048MB - $189.05'' (Lazada)
Got Dual DVI port + mHDMI for 3 monitor
[RAM] Kingston DDR4 2133Mhz CL11 (8GB*2) - $134.30** (Lazada)
[SSD] Samsung 850 Evo 250GB - $122.55'' (Lazada)
[HDD] WD Blue 1TB/64MB - $77.00
[PSU] FSP Aurum S 500W Gold 80+ - $64.51'' (Lazada)
[Case] Coolermaster N200 - $61.00
Total :- $1,076.41
Buy from PC Themes unless stated otherwise
** Buy from Lazada SG App
MasterCard Monday (15% off capped @ $25)
CitiBank Wild Weekend (15% off capped @ $25)
^^ Buy from Shopback -> Lazada SG
MasterCard Monday (10% off capped @ $25) + (5% off Shopback)
CitiBank Wild Weekend (10% off capped @ $25) + (5% off Shopback)
" Buy from Shopback -> Lazada SG
Lazada Shopback 5% off
Note* - Take 60 days to get the 5% back
Will recommend to go i3, i5 abit overkill for ur usage
[Mobo&Proc] Gigabyte B150M-D3H /w i3-6100 - $328.00
Renndo
Total :- $1,076.41
Thanks so much for all the detailed info and for taking time to do it. Im just afraid the stress takes a toll on the cpu. Seemed to do so for my last comp(512gpu quad core proc). Motherboard and graphic card burnout one after another. If youre sure i3 and 2gb gpu works for what im doing. Then im convinced.
