[Help] Fresh Built PC no Display
WhyWai88
Hi all,
First time trying to build a PC myself and ran into a wall. :(
When I power on my newly built PC, the motherboard will turn on.
But 4 out of 5 times it won't detect the Graphics Card. Nothing show on Screen..
Some times the troubleshooting VGA LED on Motherboard show White light, I can hit the reset button.
Some times it just freeze without White light, won't even respond to reset & have to unplug.
Motherboard: MSI B450I Gaming Plus AC
CPU: AMD Ryzen 2600
Graphics Card: MSI GTX 1660 TI Gaming X
RAM: Klevv Cras ii 2x8GB 3200MHz
SSD: Adata SX8200
I tried to insert another very old graphic card from my brother's 7 years old PC, the problem is the same.
Is it means that the PCI-E slot on my Motherboard is broken? Or possible is it driver issue?
Please help! I'm very clueless now.. :(
Psycovirus
Ya. You've done your own troubleshooting and found the problem. RMA that Motherboard
WhyWai88
Okay! Guess bad luck strikes.
Just try asking see if there is a glimpse hope that is was software issue..
Thank for the confirmation.
Zink00
Check ram if put correct slots.
If still cannot try with 1 stick and different slot.
Got before this problem vga led but is ram spoil.
rathalos
I have the exact same motherboard, plugging in a pcie riser extender plus a rx570 with no issues.. probably ur pcie slot is dead..
WhyWai88
Thanks for this suggestion.
Turns out really RAM is the problem!
Thanks all for the troubleshooting suggestions!
