help. ... h100i backplate loose ?
AnTiLooP
So its normal that got play/loose ? Strange !
Corsair should indicate this in their manual or something
Nostalgiaa
Make sure the backplate is aligned correctly.
There is a cutout on the backplate for the cpu socket screws.
As can be seen here.
Nostalgiaa
Had to same problem before. Turned out to be that the backplate align wrongly that's why loose. Just sharing my experience. :)
royfrosty
I did a quick removal of my H100i and remount it. Yes the back plate will be slightly loose without the front pump being mount.
Once mount the front pump the backplate will be tightened up together.
AnTiLooP
Thanks all, problem fixed..
as some of you mentioned it is by default lose.
AnTiLooP
So commach closed my other thread being commach (as as usual (it's a different topic commach, on the same product right ?? What an abuse of power... but yeah you are commach. .. )
Anyway
.. what's up with h100i and win 8.1? No love from corsair ?
ragnarok95
Senior Moderator
Senior Moderator
Anyway
Not abuse of power. Many will side with him too for closing and i am with him. Just use this thread la. Dun float the whole forum with ur H100 pls.
AnTiLooP
Commach is being commach lah. H100i 2 threads. ONE On Back Plate Problem. .One on corsair link. The 3rd is h110 temps ... so all three different topic altogether abielt 2 are same product, 1 another type. What's wrong ?.
shadow84
But all of ur problems stem frm ur h100i. So, wouldnt it better to just continue from your 1st thread, something like " Problem A is solved, and i got new problem B, how to solve?". It will make the readings much easier as well..
So, if u encounter another 10 more problems with ur h100i, you gonna open 10 more threads just for that?
Not to side with commach or anyone, just my 2 cents.
AnTiLooP
Fine. My bad. And you got a point shadow and thanks for rationalising.
