[Help] Hangs during browsing
Gambler.
Just built this pc about 2 months ago. Has been experiencing frequent hangs during normal browsing of the web, nothing really resource hungry that I'm doing.
Is there somekind of bottleneck? How do I go about troubleshooting
Mobo: AMD Ryzen 5 2600 3.9ghz
CPU: MSI B450M Bazooka Plus AM4
RAM: Kingston DDR4 2400mhz 8gb x 2
GFX: Galax GTX 1050 2gb
PSU: Silverstone 500W 80+
SSD: Crucial MX500 500gb (1 week old, just changed from Newegg BF)
HDD: WD 1TB green
TIA!
Koenig168
You can try disconnecting the HDD and see if the problem recurs.
rEe_TaN
Which Windows Build? And are you running on Chrome? Also, are you running on Nvidia Experience?
Google Chrome & Nvidia Experience has been giving issue. Change to other browser and uninstall nvidia experience to see if it helps you or not.
Gambler.
Windows 10 Pro.
It always hangs whenever I'm browsing using Chrome :s22:
EDIT: Sorry, I don't have Nvidia Experience installed.
rEe_TaN
Windows 10 Pro.
Uninstall chrome and use firefox to see if it helps you or not.
Windows 10 1709 build? or 1803?
Koenig168
thanks!
Just for my understanding, why would the HDD be the first you suspect?
A bad HDD or connection can cause system slowdown or freezes. I usually test this first since it is easy to do.
Gambler.
1809, just installed 2 days ago
I'm going to try FF now and monitor the freezing.
Thanks for the suggestions!
Gambler.
if it helps, I actually have another 320gb HDD too.
OS is installed on the SSD.
rEe_TaN
Wa latest oct update and i didnt dare to try. Previous build already given many problem. Good luck though!
Gambler.
oh i just got the new SSD, so I fresh installed a new copy of windows which was the latest available. :s13:
Soul77
Most probably hdd/ssd issue. Before you use the new ssd, did you encounter hang issue also?
Gambler.
only happens after i built this pc
old pc with the current hdd/ssd got no issues
i reused the SSD and HDD until I got the MX500 few days ago
rEe_TaN
If just when freeze during browsing, likely software issue. Not all freezing/hanging is caused by hardware.
