Help!! High Mobile Data Usage on Huawei P20 Pro. WTF is featurelayerwidget??
ngsteve
Hi,
The following screenshot(My Data Manager on data usage consumption) is from a huawei P20 pro andriod handphone.
Its been consuming a large amount of mobile data...Top of the list is featurelayerwidget.
Whad is this featurelayerwidget that is consuming 207MB of my mobile data on one day??
There is no app or widget on my handphone by that name that I can just uninstall
Does anyone know whad it is?? Whad can I do to reduce my data usage??
Thanks
ngsteve
So no one knows whad it is and why it is consuming so much data??
featurelayerwidget?? any info?? how to get rid of it?
chenaz
You can try to delete the my data manager.
Do you know that third party data tracker consume a lot of data?
For iPhone we have this mobile data consumption for each app. In the app I found out that is the third party data tracking that consume so much data.
Paul Lee
It's not My Data Manager. It consumes very little data (<1MB) even over WIFI. ngsteve did not show it but there is a separate entry for this app.
joshiru
Use the phone manager app that comes with phone to see if it tells you the same thing?
Phone Manager > Mobile data > Data usage ranking
chenaz
Yes.
Or maybe is Google bug like the link I posted earlier.
Google also admit that there is a big in Android that consume a lot of data
ngsteve
It does not show the 200Mb data usage featurelayerwidget in the App Usage ranking in the settings of my hp......strange la.....top of the list is Whadsapp....and t uses less than 50Mb of data lol...werid la
Anyone has a or knows of a good sample source code open source data monitoring app like on Github source depository for Andriod...MainActivity..to monitor data usage further??
Ok found some stuff on the trafficstats API on andriod
https://developer.android.com/reference/android/net/TrafficStats
and
https://www.quora.com/How-do-I-get-mobile-data-usage-statistics-programmatically-in-Android-Any-APIs
