Help in building a gaming PC
spaaaz
Need some help in building a gaming PC. Want to run games such as CSGO, hearthstone and sc2 very smoothly. For reference, i want my fps on CS to be able to reach 200-300? I may play some other more taxing games as well (Battlefield, skyrim etc.) but i don't need to run them on the highest settings. Just looking for it to be smooth. My budget is probably not more than 1k.
thanks guys
MoneyFace =p
Need any of these?
Windows
Monitor
Speaker
Keyboard
Mouse
WiFi adapter
PC to be placed on table or floor?
Which internet provider plan and router are you using now?
Is your home in a relatively new apartment built in the past 8 years?
How far is your upcoming PC located from the router?
Any obstruction between path?
spaaaz
I need windows and i'll be connecting by a CAT6 ethernet cable. PC can be placed on floor or the table (doesn't matter to me, i have space for both). Currently have Singtel Fiber 1GB. My apartment is relatively new since i have fiber. My router will be ~1.5-2metres away from my upcoming PC (I have a ~5m CAT6 cable so no problem). No peripherals needed, I have everything that I need. (KB, Mouse, Monitors etc.)
Thanks for the reply
MoneyFace =p
CPU+MB: Intel Core i5-4460 + ASRock H81M-HDS R2.0 @ $343
RAM: Kingston ValueRAM DDR3-1600 CL11 8GB @ $67
GPU: Zotac GTX 950 2GB @ $244* (Lazada Singapore)
SSD: Samsung SSD 850 EVO 250GB @ $139 (Lazada Singapore)
HDD: Western Digital Blue 1TB @ $77
CASE+PSU: Armaggeddon Microtron T2X + FSP Hexa+ 550W [80 Plus] @ $102* (Lazada Singapore)
OS: Microsoft Windows 8 Professional 64-bit Product Key [OEM] @ $28 (Reddit)
Upgrade for free to Windows 10 via free Windows 8.1 update.
Total: $1000
Buy others from PC Themes, #04-15. Haggle for discounts!
*Price after Lazada App MasterCard Monday / DBS/POSB Appy Friday / CITIBank Wild Weekend 15% off max $25 discount
dennis23
CASE+PSU: Armaggeddon Microtron T2X + FSP Hexa+ 450W [80 Plus] @ $94* (Lazada Singapore)
Total: $992
Perhaps he should skip the SSD for now and invest in a better GPU? SSD can always be added in later but GPU upgrade will mean replacing the card.
@OP: If you're not too particular about it, you can get some pretty good deals with second hand parts that are still under warranty.
MoneyFace =p
TS doesn't really require higher end GPU for now and even if we drop he can only get a R9-380 which is not a big improvement over GTX 950. Plus GTX 950 is still be to handle BF and Skyrim well on mid setting.
And if you were to add SSD later, TS may need to reinstall the entire OS and games on the SSD. A GPU upgrade later should it be necessary for him, will be much simpler.
spaaaz
oh yea. forgot to add in that I have a 144hz monitor. Will i be able to utilize this refresh rate with that GPU. I've heard that certain GPUs aren't preferable/suitable with 144hz monitors (Max refresh rate only able to reach 60hz)
MoneyFace =p
Yes this is perfect for that, with HDMI 2.0, DL DVI and DP1.2. GTX 950 and GTX 960 are the only 2 cards to support HDMI 2.0 out of the box right now....
reyer_
Shouldn't he try to use the 50 dollar coupon from qoo10 if he can get to get a gtx960?
spaaaz
sorry so to confirm again. the GTX 950 WILL work/be able to handle a 144hz monitor?
Bentham98
Need some help in building gaming pc
Need some suggestion . Budget will be 1.1k including the ( nzxt h440 case ) . I will be using it for gaming . Games like LoL , Tera and GTA V medium to high settings 60 fps .
intrance
Hi.. open a new thread for your queries and answer below question for others to advise you better..
Need any of these?
Windows
Monitor
Speaker
Keyboard
Mouse
WiFi adapter
Phen8210
If want minimum 200 better get CPU skylake,
For GPU after a certain point does not increase your fps anymore in cs:go, GTX 950 is a sweetspot.
This is my benchmark for CS:GO, PC specs on the right, -high -threads 4
2015-12-24 14:17:56 - csgo
Frames: 86784 - Time: 380438ms - Avg: 228.116 - Min: 160 - Max: 293
MAP: Done in inferno, 20 player Deathmatch valve server.
My video settings
