-Synchronicity-
- Apr 29, 2012
Because you can find the 1070ti at a cheaper price. 2060 will all hover around the same price because new product
If u intend to get a gfx to be used for the next 5 years, go for 2060
I guess because in the next 5 years you'll get more games that supports ray tracing. At least can switch it on for some games and see see look look. Not taking into the account any performance deficit.Why? This makes 0 sense when 1070ti has the same performance. So you mean same performance but won't last the same 5 years? I really don't get the logic.
Coincidentally i am also looking to get a new PC. Pretty noob here so i went to aftershock directly as they are having some kinda discount. Need some feedback here:
Warranty (Desktop) : 3 Years Parts Warranty (1st Year ONSITE)
Chassis : Bolt : Bolt Black Edition Tempered Glass
DESKTOP MOTHERBOARD (BOLT, ZEAL) : ASROCK Z370 Motherboard (Support wifi and bluetooth) (Overclocking capable, for Intel K series processors) 4 Ram Slots
CPU (Bolt) : Intel® Core™ i5-8500 Coffee Lake 6 Core Processor (9M Cache, up to 4.1 GHZ)
Thermal Compound : IC Diamond Thermal Compound CPU (Free Lifetime Thermal Compound Re-pasting)
Graphics Card (Bolt) : NVIDIA GEFORCE GTX 1060 3GB GDDR5
CPU Cooling System (Desktop) : INTEL/AMD stock cooling fan solution
Memory (Bolt) : 8GB (8GB x 1) DDR4 2666MHZ KLEVV RAM
Solid State Drive, Bolt : 256GB PCIE M.2 SSD (Over 1100 MB/s Read Speed)
First Hard Drive (Desktop) : TOSHIBA 1TB 3.5 INCH HDD (Buffer Size 32MB)
Chassis Fans : Standard Chassis Fans
Total cost is $1,235. Does anyone know if i can build a pc with similar specs at lower cost or same cost but better specs? Thanks
best deal is always oversea but you must account for shipping feeHi all!
Looking to purchase a new 500gb/1tb SSD..what's the best deal now?
Thanks.
Sent from the further using GAGT
Ah I see thanks!best deal is always oversea but you must account for shipping fee
locally, i would say sx8200 pro is best overall ssd
