help in pc build
wtfwfs
hi all.
looking for a pc build
1.5k
playing games like, dota2, cs:go, battlefield4, evolve (upcoming game), tomb raider
looking for a setup of 1HDD, 1SSD, 1cd reader,
not sure about the mobo and cpu combo (asus,gigabyte,msi with intel processor), but then will be using only aircooling so looking for case with more fan options (2top,2btm,1side,1rear if possible)
need suggestions for gpu too...
MoneyFace =p
CPU+MB: Intel Core i5-4460 + ASRock Fatal1ty B85 Killer @ $347
RAM: G.Skill RipJaws-X DDR3-1866 CL9 8GB Dual Channel Kit [Red] @ $117
GPU: Palit GTX 970 4GB JetStream @ $475* (Lazada Singapore)
SSD: Crucial MX100 256GB @ $154
HDD: Western Digital Blue 1TB @ $68
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: Super Flower Golden Green HX 600W [80 Plus Gold] @ $108
CASE: Corsair Carbide SPEC-02 @ $84
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Total: $1489
Buy others from Tradepac, #05-19. Haggle for discounts.
*Price after MasterCard Monday discount
wtfwfs
thanks for the reply,
for the cpu and mobo combo, my friend said that he will stick with at i7 processor, so any other sugguestions to find into his budget of 1.5k (sorry forgot to say that 1.5 will be inclusive of pc screen.
nippp0n
There is no significant difference between i5 and i7 when it comes to gaming. So why does your friend insist an i7? You can do a simple google search and show him the benchmark result.
royfrosty
Total: $1489
This will rock your friends off for all the games at max settings.
Ram may go 1600mhz instead as B85 limitations to 1600mhz only. But up to you as it is only $2-3 away.
MoneyFace =p
CPU+MB: Intel Core i5-4460 + ASRock H81M-HDS @ $299
RAM: Crucial DDR3-1600 CL11 8GB @ $96
GPU: Palit GTX 970 4GB @ $457* (Lazada Singapore)
SSD: Crucial MX100 256GB @ $152* (Lazada Singapore)
PSU: FSP Hexa+ 550W [80 Plus] @ $69
CASE: Xigmatek Recon @ $45
DSP: Dell S2340L 23" LED [eIPS] @ $199^ (SITEX 2014)
In just a month's time.
Potentially bundling with free HDMI cable.
Total: $1521
