help in recommending value for $ mobo or bundle
liewhl
my mobo is faulty and I am looking to replace it .
looking to buy new mobo, but do not know which to buy.
currently I am using gigabyte p55 ud3 with i5 1st gen
shld I just buy a new mobo and reuse my old cpu or shld I replace the mobo with the cpu?
which brand and model shld I buy? value for $ mobo or mobo bundle will be great.
GrimaH
You won't be able to find a new P55 mobo for any decent price, unless by some miracle you come across any shop clearing their old stock. If you don't mind secondhand though, P55 mobos can be had for less than $100 (usually), if you do some scouting in the sales subforum.
Otherwise, the usual Haswell i5 + B85 mobo combo is about $360+ on mynextcomonline.com.
Swiftbladez
If just buy mobo you can go for a second hand one.
Otherwise get new bundle should be more value for money.
^What he said.
liewhl
i not looking to buy back the same model of my old motherboard.
so any model/ brand is fine with mobo? and also only p55 support i5 1st gen?
MoneyFace =p
Wait. Core i5-6xx or 7xx???
MoneyFace =p
If you find your current Core i5 still satisfying, then you should scavenge for any H55/H57/P55 motherboard...Ask distro, buy from reseller, be it 1st or 2nd hand...
muddle
Yup. No more new p55 mobos. As for brand, get one with the features you need.
