Help in rooting oppo
Cynn2016
Hi, i dont know if this is the right place to start my thread. But does anyone knows how to root oppo r11s so that i can customise the whole font and themes? :s11:
ZrE0_Cha0s
U can try asking in the mobile section where there is an oppo thread.
lenseview
Try searching in xda forum. For rooting, theres always the risk of bricking phone. No matter hard brick or soft brick.
guyz92
If your phone support bootloader unlocking, you can use Magisk Systemless root.
To test if the patch image works, you can use fastboot to boot custom image without flashing it.
amazingone
I don't think you can root OPPO phone, because their bootloader can't be unlock.
Cynn2016
i have the oem unlock option in developer mode and im unsure if it actually allows the bootloader to unlock πŸ˜₯
Cynn2016
Got step by step guide link?
bunnypangsai
try typing the model and the term for rooting in chinese? maybe you will have more luck there
