HELP iphone stuck at recovery mode
mnest18
Hi guys, appreciate some help/advice here..
So basically, I was trying to backup my iPhone 7 to my computer. However, either due to the cable being faulty or my phone having too little storage space left (about few hundred MB), the backup on iTunes failed.
I plugged out the cable and tried to use my phone but it got a bit weird (deleting photos from my photo album went to white images instead of them being deleted).. so I went to restart my phone and it got stuck at apple logo
So I tried several online methods to solve this and ended up in recovery mode/DFU mode (screen showing iTunes logo and cable)...
Is there any way to keep any data on my phone (photos, etc) bcos I couldnt find a way to do it.. most places say that the only way is to wipe my phone and restore it...
mnest18
Anyways, when I try to plug it to iTunes and select the update option (to keep the data), error 14 comes out when updating the iOS. Is it bcos my phone does not have enough space but I can't do anything about it
mnest18
yep, i have tried a diff cable. i think now the problem is not the wire, is my phone thats somehow screwed in iOS or something.
i tried to update on itunes but cant
is there any way i can fix the error? i suspect is either my software is corrupted already or there isn't enough space to update the iOS (my phone had about few hundred MB space left before this) but i cant free up space in my phone now since its stuck
PetPet
Moderator
Moderator
Maybe the Apple Store at Orchard? idk, give it a try and see what they say.
yotoden
Try different USB port or Computer maybe, also different Apple ORIGINAL lightning cables, update iTunes software, any luck?
mnest18
yeah tried all already, anyways went to sim lim square and just showed them the screen and they said wouldnt be possible to retain the data inside :(
i guess there's no other way except to restore it? damn sian all my photos inside later gone
szeli
u tried  Store also?
*adiBOY
Go download ReiBoot and give it a try. Might help you :)
gkhchay
Do you do regular backups on iCloud? If you do, then it’s nothing to worry about because all data, apps & photos will be on iCloud so even if you need to erase all data from your phone, they are still on iCloud & can be easily restored.
mnest18
unfortunately, i didnt backup on iCloud, which turns out to be a painful lesson..
guess I'll do that from now on
still trying everything i can to salvage my data though...
*adiBOY
Have you tried ReiBoot?
mnest18
the full version requires me to pay though
previously i have paid for dr.fone which had almost the same purpose but it didnt work so im afraid to pay for something that wouldnt work again
anyway dont these paid programme serve the same purpose as itunes?
with update/ restore options similar to itunes
*adiBOY
You can use the restore from DFU mode with the free version.
mnest18
its fine hahha i decided to restore from itunes and restore my backup in january this year cos it seemed like i was never gonna get back my stuff my phone
the update option to try to fix my phone on iTunes always ended up in error 14 when the progress bar on my iphone along with the apple logo always loaded up to 1/3 then error 14
warehaws
iphone will usually get slow when less than 3GB free storage.
if I hit low storage, I will enable the Photos "optimise iphone storage" option and will then get a bigger GB storage on next purchase/upgrade of phone.
recommended is enable the icloud backup for daily use, pay monthly 50GB or 200GB
then do manual itunes backup(new) when there is a major ios version upgrade.
yotoden
Can use google photos or etc to backup to cloud (if want free option).
Also should practice to clean up photos more often.
