Help ! Is my memory too low ?
watzup_ken
Where there are a lot of people or characters rendered on the same screen, the Cpu is under heavy load. A i7 7500U may not be able to manage the load as it is limited by both power and thermals.
Neptunes43
Possibly. What is clear now tho, is that your memory is not the issue. What you're describing tho sounds like an internet issue more than a CPU one as some of us suspects. Try using a wired connection like what the others suggested, and monitor your ping in the game. Ping past 200 is a good indicator that internet speed is the underlying issue.
So now is my CPU and not my memory ???? :eek:
hlots123
paiseh side qn tats completely unrelated to ts problem, how to get
12gb ram
dual channel
1 slot used/1 spd slot
izit this speccy only 1 out of 3 correct?
Godeau
12gb ram
dual channel
I have never seen a single slot 12gb sodimm ram before, so speccy might be incorrect
So TS, have you tried monitoring your ping using lan cable connection like others have mentioned?
By the way, Mu Legends is a terribly optimized game
