The information in the dump is not the system according to the profile (right pane). The dump stack show only atikmdag.sys hence the main culprit at this point, especially with the first argument "C0000005", this is a memory access violation, the ATI driver attempt to access an out-of-bound memory Noticed you are running FlashPlayer when the system crash, update Flashplayer as well to narrow the problem.
The ATI driver is updated recently in 12 August, if the problem arise after this update, uninstall it then reinstall the previous version.
BugCheck 3B, {c0000005, fffff8800f4e829c, fffff88007f02950, 0}
Probably caused by : atikmdag.sys ( atikmdag+b129c )
Followup: MachineOwner
1: kd> !analyze -v
* Bugcheck Analysis *
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8800f4e829c, Address of the exception record for the exception that caused the bugcheck
Arg3: fffff88007f02950, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
You got an outdated driver, if you are still using the WD webcam, update the driver (if available), else uninstall it.
wdcsam64 wdcsam64.sys Wed Apr 16 16:39:08 2008 (4805BB2C)
The Asus B85 Plus BIOS is the 04/08/2013 version, if you still encounter the same problem after completed the aforementioned, update the BIOS as well (if available). The i5-4430 CPU @ 3.00GHz thus we rule out problem arise from overclocking.
