[Help] Liquid Cooling for i5 8600k
watzup_ken
Why get a cooler that don't really allow you to overclock when you are getting an overclocking chip in the first place? Anyway, there are plenty of good air coolers that can do better than using this liquid cooling. Liquid cooling sounds cool until it starts giving you pump problems or start leaking. :o
shengheee
Ya. But i don't know if the air cooler is tall enough or too tall for my mini itx case.
riotpatriot
https://pcpartpicker.com/b/xwGfrH
Cryorig H5. you see you like ornot
watzup_ken
I think you can easily find the dimension of the case and measure isn't it? My understanding is that the motherboard is vertically mounted for this case, and should fit some decent tower air cooler. This information is in fact readily available on Fractal Design's site. The site says, "CPU coolers up to 160mm in height".
